Author Topic: DIY Exhaust System - Custom Exhaust Done at Home  (Read 6747 times)
« on: September 16, 2022, 01:36:53 PM »
An old article....needed info related to over the axle fab...
https://www.motortrend.com/how-to/diy-exhaust-system-custom-done-at-home/
Re: DIY Exhaust System - Custom Exhaust Done at Home
« Reply #1 on: September 16, 2022, 02:03:30 PM »
I made mine at home all out of J and U bend tubing (2.25" diameter).
« Reply #2 on: September 16, 2022, 06:34:04 PM »
That's what I want to do with my 33,,,have any part/kit numbers?
« Reply #3 on: September 16, 2022, 07:24:49 PM »
Ed,
No kit.  I did a layout and fabricated it all from scratch.  The trick is to get the right bend radius to get over the rear axle and have the clearance you need.  I can go back and look at what worked for me to help you out.  I have rear leaf springs which gave me more room than a four link or triangulated four link would have.
« Reply #4 on: September 17, 2022, 08:44:56 PM »
Thanks Tom..don't worry about it right now.  I need to get my four post ceiling opened first...so I can actually work on the exhaust.
« Reply #5 on: September 18, 2022, 01:51:00 PM »
Pretty sure I bought a kit from Speedway or JEGS, had a bunch of U's and angles, you have to cut and weld them to fit your application. The kit came in various diameters.
« Reply #6 on: September 18, 2022, 05:34:39 PM »
I used one of the kits from Speedway when I built mine. I didn't need it all to do the job but like anything else I've used it all up on various projects over the years...Here's a link to take a look at.
https://www.speedwaymotors.com/Search?query=exhaust%20bend%20kit
« Reply #7 on: September 18, 2022, 09:13:23 PM »
Thanks Guys!
