Author Topic: Rear shocks  (Read 8259 times)
Rear shocks
« on: May 18, 2019, 06:45:08 PM »
Hopefully I'll be tearing into the 32 next month.
When I do the steel, im gonna remove the rear floor and convert to modern shocks and also new leafspring's.
Let's see your rear shock set ups ?
« Last Edit: May 18, 2019, 07:24:23 PM by Rattiac »
Re: Rear shocks
« Reply #1 on: May 19, 2019, 07:48:42 AM »
Here is an old post with a mod I came up with...not sure if it applies to your plans but it has been working great for us.
http://rustybowtie.com/index.php?topic=1369.msg13105#msg13105
Re: Rear shocks
« Reply #2 on: May 19, 2019, 11:48:34 AM »
Here's my set up.
Re: Rear shocks
« Reply #3 on: May 19, 2019, 03:14:54 PM »
Thanks guys.  8)
Tfoch , are those custom length shocks OR from a camaro or something ?
I may try camaro shocks since I have camaro brakes. Plus I can measure off my dad's car.
Gonna use air shocks cause the teardrop trailer.
Re: Rear shocks
« Reply #4 on: May 20, 2019, 07:04:10 AM »
They came with the leaf spring kit I got from Posie's.
Re: Rear shocks
« Reply #5 on: September 18, 2019, 02:31:08 PM »
Now that the leafspring's are done, I've been looking at shocks.
Trying to go with something O.E. . For future replacement.
 1980 Malibu rear air shocks seem to fit the bill in weight and wheelbase. Plus was trying to stay away from the (stud) type shocks.
I may have to order a upper shock mount bar.
A few details to work out before ordering.
Re: Rear shocks
« Reply #6 on: September 20, 2019, 08:18:51 PM »
I forgot how fast Summit is. Ordered the shocks yesterday and they had em to me at 2 p.m. today.
 :o 8) 8)
Re: Rear shocks
« Reply #7 on: September 22, 2019, 07:27:02 PM »
Mocking up the shocks today.
Is there any downsides to mounting them in Front of the axle ???
I can mount them behind it but there's way more room up front.
The mounts should be here soon.
Re: Rear shocks
« Reply #8 on: September 22, 2019, 08:07:53 PM »
I don't believe it makes much difference. I've seen stock locations be behind, above and forward of axle. 57 Chevy, C2-C3 Vettes are forward. Hell 2nd gen Camaro was rear on left, forward on the right   ;D  (was suppose to help control wheel hop)  ;)
Re: Rear shocks
« Reply #9 on: September 23, 2019, 07:52:19 PM »
Ohh, my jeep is set up like that. :)
 They'll probably be in front then if there isn't any issues.
Re: Rear shocks
« Reply #10 on: September 25, 2019, 08:35:36 PM »
I have a silly question
(not worth starting another thread over)
Butt , it's related.😉
I need to fit this cross member into the framerails tightly.
Is there any tricks to getting this  2" square tube in without cutting it too short ???
I had this problem putting in the engine mount bar and I did cut a bit short but was able to weld in a flat plate spacer. Would like to avoid that again.
Re: Rear shocks
« Reply #11 on: September 25, 2019, 08:52:22 PM »
Measure twice. lol  If I need a really tight fit that has to be right, I always grab a cheap stick of conduit. Measure, double check and cut the conduit and test fit. If all good I use it as a pattern for the real deal expensive part ;D
Re: Rear shocks
« Reply #12 on: September 25, 2019, 09:46:38 PM »
Im usually triple checking myself if not more.
I was referring to getting it between the c-channels since my frame isn't boxed yet.
Getting it in there diagonally and I guess beat it until it pops in. Right ?
Re: Rear shocks
« Reply #13 on: September 25, 2019, 10:42:44 PM »
Ah, sorry. Missed that part.
Yep, pretty much. I would just bend the leading/trailing end of those mount tabs in. Start in place, smack it in then vise grip ("C" clamp) the tabs back straight, and hammer chissel/punch on it (while still clamped) to put the "set" back in it.
That frame should have enough flex for the bar to go in. (If it's not close to a crossmember there).
Hope it goes smooth for you!
