Author Topic: bought some ebay fuel injectors .... thoughts?  (Read 8229 times)
28chevyguy
« on: April 02, 2019, 04:25:46 PM »
anyone ever bought injectors off ebay? got a set of 8 for 50 bucks … really cheap .   Got them today, they actually have bosch part numbers on them but the box says china??
I have a high hp Pontiac grand prix turbo retuned with 36lb injectors , they were used but professionally cleaned before installed with the tune , the car ran amazing but now years later is making white fuely  smoke and the car is running pig rich 10:1 !!!!
fuel regulator was tested and seems to work fine, im leaning towards a mechanical malfunction within the injector (s).
as if one of them is sticking open ,  being Multiport rather than series injection , that doesnt help much either!
So i bought these new injectors but im kind of weary installing them with the china logo on the box ???  i was reading the china injectors dont have the bosch numbers on them but these ones do ...  i really dont know what to think about them .
The only thing keeping me from driving the car is this white smoke so i really need to get it figured out ,, its not oil smoke or coolant.
Re: bought some ebay fuel injectors .... thoughts?
« Reply #1 on: April 02, 2019, 04:35:26 PM »
Have you tried a laser temperature gauge on the exhaust header to determine if all eight are approx at the same temp?
28chevyguy
« Reply #2 on: April 02, 2019, 05:04:42 PM »
no i don't have one of those, should grab one as they are great tools for tuning.  I have custom log manifolds anyway , im actually cracking the upper intake off right now .  going to get a quick ohm count on them first
so i have 11.5-11.6 across the board, going to try to watch the spray pattern now... another dam gremlin
EDIT    FIXED ....got off easy this time ,  just tossed them in and no more smoke.  will see how they hold up under boost .
« Last Edit: April 02, 2019, 07:16:29 PM by 28chevyguy »
« Reply #3 on: April 03, 2019, 09:52:27 AM »
Sounds like an easy fix. You bought them, might as well try them ;D
28chevyguy
« Reply #4 on: April 03, 2019, 07:09:16 PM »
yea there was no mention of china but I should have known... dam china logo was big on the box too hahaha freaked me out
« Reply #5 on: April 03, 2019, 08:01:51 PM »
From what I've read about injectors they seldom fail but they do get clogged and gummed up.  Sending them out for cleaning/flow check gets expensive (over $20 EACH).  There are several DIY videos on how to clean them at home.  Good advice to use a heat gun on the headers which may give you lots more info.  Have you checked the O2 sensors?
28chevyguy
« Reply #6 on: April 03, 2019, 08:45:21 PM »
Yea the last  set was sent out but they were abused for about 5 years over all … hard boost takes a toll.
The car is perfect now all fixed ,  air fuel ratio at idle went from 10:1  back up to normal approx. 13:1  maybe a little higher than that.
« Reply #7 on: April 03, 2019, 08:48:51 PM »
I use STP or another brand of FUEL INJECTION CLEANER right in the tank every 4 tanks.  They used to have tv commercials by STP showing a fine mist spray instead of semi clogged stream.
Convinced me.  Never had an injector taken out to have serviced .  And I keep my cars until the end.
28chevyguy
« Reply #8 on: April 03, 2019, 10:34:24 PM »
yes I agree with cleaning them but in my case one had a mechanical malfunction , over fueling … the opposite of being clogged.  You can ohm them and keep em clean as you want , if they mechanically fail … it will need rebuild or replace.
