Author Topic: Brakes  (Read 25141 times)
Re: Brakes
« Reply #15 on: March 27, 2019, 06:05:35 PM »
I had someone pump the brake for me while I looked and there is no movement at all up front. I removed the rear drum to watch while brakes were pumped and no movement at all.
Just doesn't make sense to me as all the air seemed to be pushed out.  The only thing different besides being ide for seven months is the addition of the remote reservoir.
Re: Brakes
« Reply #16 on: March 27, 2019, 07:55:29 PM »
If your installed new master cylinder and booster...Is  the rod from master cylinder into booster adjusted correctly??
Re: Brakes
« Reply #17 on: March 27, 2019, 08:18:06 PM »
If this is not adjusted properly you will not get any movement, try loosening the nuts on the master cylinder and booster connection, as you loosen them if the m/c pushes away from the booster the rod is two long and needs adjusted ( it's left handed threads) If this is the case the cylinder piston is past the ports and no fluid can flow but you will still have pedal movement. I've seen guys put washers between the m/c and booster, I don't recommend this.
Re: Brakes
« Reply #18 on: March 27, 2019, 08:33:12 PM »
Also is the rod from the pedal to booster in adjustment????? I would check this first
Re: Brakes
« Reply #19 on: March 27, 2019, 09:27:29 PM »
Another thought, if you have proportional valve did you trip it, if so you will need to reset it.
Re: Brakes
« Reply #20 on: March 28, 2019, 08:59:57 AM »
Yes I adjusted the rod according to the video provided by Speedway.  Don't know about the proportioning valve as I didn't mess with it.  It has a knob adjustment and I don't know how to set it.
Re: Brakes
« Reply #21 on: March 28, 2019, 09:07:34 AM »
Was that a video on the rod from booster to master cylinder adjustment?? Did You check for from pedal to booster???
Re: Brakes
« Reply #22 on: March 28, 2019, 09:24:13 AM »
It was the rod from the booster to the MC.  The pedal to the booster I adjusted same as the old one.  I left it retracted and adjusted the clevis to the pedal in the up position.
Re: Brakes
« Reply #23 on: March 28, 2019, 02:32:41 PM »
I haven't had anyone help me bleed brakes in years....and I don't use a vacuum bleeder.
ED,
Do you gravity bleed one at a time or all four?
Re: Brakes
« Reply #24 on: March 28, 2019, 03:10:35 PM »
ED,
Sorry, I reread your post. Thanks
Re: Brakes
« Reply #25 on: March 28, 2019, 03:37:27 PM »
Wish I right there to help...did you bench bleed the MC just to be sure that it's even working.
Re: Brakes
« Reply #26 on: March 28, 2019, 04:16:59 PM »
Yes, but I just forced all the air out as shown, I didn't try to operate it.
Re: Brakes
« Reply #27 on: March 28, 2019, 05:47:44 PM »
FYI:  https://www.youtube.com/watch?v=vOTkVAeU_n4
Re: Brakes
« Reply #28 on: March 28, 2019, 05:58:09 PM »
Yea, I just forced air through the ports.  I've been gravity bleeding all day and no luck.  I guess I will take it back down, bench bleed the MC correctly and start over. Tomorrow though, I just don't have it in me right now.
Thanks Ed...
Re: Brakes
« Reply #29 on: April 01, 2019, 10:24:57 AM »
Persistence, I finally got a pedal and now I'm off to cruising...
