Author Topic: Wieght  (Read 5911 times)
Wieght
« on: December 20, 2016, 12:53:14 PM »
I am trying to size coil over springs and wondered if anyone knew the approximate tear weight of a 1930 Coach?  It has a 16 gallon fuel tank.
Re: Wieght
« Reply #1 on: December 20, 2016, 05:22:07 PM »
I am showing 2515 lbs. curb weight, if that helps.
Re: Wieght
« Reply #2 on: December 20, 2016, 05:49:03 PM »
I think I did come across a formula for using that, thanks
Re: Wieght
« Reply #3 on: December 20, 2016, 07:22:42 PM »
Chopper,
Is that the stock weight?
Re: Wieght
« Reply #4 on: December 21, 2016, 05:51:25 PM »
Yes, stock weight.
Re: Wieght
« Reply #5 on: December 21, 2016, 09:26:18 PM »
I usually run 250 lb to 275 lb rear spring coils. Mounted at 30 degrees of pitch on the coilover shock.
