Author Topic: What do you call this steel channel?  (Read 6481 times)
« on: October 04, 2016, 11:32:37 PM »
Making a flatbed and need some channel like in the first picture.  Can find the standard channel like in the 2nd picture but that tapered opening doesn't allow for the deck boards to seat fully inside.
Years ago I had a shop cut and form my channel from a 4X8 sheet of 9 gauge..I'm sure someone sells the formed channel..but for search purposes..what is it called?
Re: What do you call this steel channel?
« Reply #1 on: October 05, 2016, 07:13:23 AM »
Ed,
The second picture is called U Channel.  You can look it up on McMaster Carr.  The first picture is also U Channel but formed from sheet metal.  Didn't see any on McMaster's website but I'd check with your local steel guy.
« Reply #2 on: October 05, 2016, 07:25:19 AM »
Thanks Tom..I can locate the standard U channel but not the formed version. My choices around here are limited-  may need to look over in Vermont or downstate NY.  Tried searching for the formed U channel with no luck.
« Reply #3 on: October 05, 2016, 07:30:52 AM »
Ed,
Found this on a google images search of u channel steel.  They mentioned "rolled steel framing".  Hope it helps.
http://www.mristeelframing.com/accessory-products/
« Reply #4 on: October 05, 2016, 07:34:42 AM »
Looks like it's described as "formed U channel"
« Reply #5 on: October 05, 2016, 09:43:51 AM »
I usually have to have mine made. Good luck with your project.
« Reply #6 on: October 05, 2016, 10:53:59 AM »
Thanks guys - located this business not far from here in Vermont, asked them for a quote.  FYI good source for truck frames etc
http://www.pgadams.com/
« Reply #7 on: October 05, 2016, 06:07:43 PM »
I would think any machine shop would be able to form it for you if  they work with sheet material
« Reply #8 on: October 05, 2016, 08:08:28 PM »
Rec'd the estimate, for (2) 9 foot and (2) 7.5 foot pieces of channel  5" height..well over $1100. I can buy a complete bed for that amount.
I have plenty of 4" channel that was given to me...and will be using it.
« Reply #9 on: October 05, 2016, 09:46:55 PM »
Wow Ed. Must be made from gold bars.
« Reply #10 on: October 06, 2016, 10:16:47 AM »
On another note, this outfit has some pretty neat kits:
www.kansasflatbeds.com
