Author Topic: Who runs a spare tire?  (Read 26697 times)
Re: Who runs a spare tire?
« Reply #15 on: March 15, 2016, 04:18:49 PM »
I never know when I might not be welcome at home. ;D
« Reply #16 on: March 15, 2016, 07:07:12 PM »
I just carry a can of Fix-A-Flat  ;D I did however just pick up a space saver that I hope will fit.
As far as tools, when I am driving around town I don't take anything. Longer drives I load up a small toolbox with everything I can fit and a roll of Gorilla tape!! You could tape your "U" joints together with that stuff!
« Reply #17 on: March 15, 2016, 07:42:19 PM »
I could probably get one of those space savers behind my seat, but it would have to be both ford and chevy to satisfy my bolt patterns.
« Reply #18 on: March 15, 2016, 08:43:56 PM »
Dang Sixball you need a motor home with all that you carry.
« Reply #19 on: March 17, 2016, 12:50:09 AM »
Lads I came across this cite and i just figured that this would be worth sharing  have a weeee look:::::http://www.how-to-build-hotrods.com/tips-and-tricks.html.  Sure hope this gives someone some great hints  vette59jdwl
« Reply #20 on: March 17, 2016, 09:28:39 AM »
  Thank some good ideas Vette, the link on the "Peel-N-Stick" for sound deadener is exactly what I used in the 30.  Great stuff...
« Reply #21 on: March 17, 2016, 11:37:22 AM »
  Ok was in the garage and pulled this out of the trunk  will measure today and give the measurments.This is the doughnut out of the corvette.  vette59jdwl:::::::
« Reply #22 on: March 17, 2016, 05:37:00 PM »
Peel & Seal is very affordable and works great with no smell
« Reply #23 on: March 17, 2016, 06:29:09 PM »
  OK This is a picture of the back side of the spare  it has a 3-1/8 center hole it is 5 on 4-1/2 and 5 on 4-3/4 total height 23/1-2 inches
« Reply #24 on: March 21, 2016, 11:35:10 AM »
Great, maybe I can score some fenders like MadMike, or the wheel wells, and use something like that.
« Reply #25 on: March 21, 2016, 12:33:15 PM »
One of the problems with using an original side mount welled fender is the size of the opening in the fender.
 You need to find a 4 inch wide rim........like a GM  ralley wheel 15 x 4" and a 78 series tire that's narrow enough to fit into the well.
Back in the late 60's most of the pony car makers GM FORD AMC made inflatable spare tires, usually 14".  Not sure what the rim size width is on one of them, never had the tire popped off to measure.
« Reply #26 on: March 21, 2016, 07:04:49 PM »
Mike,
I was thinking a doughnut would fit, but not sure how good it would look.  I see Ebay has the tire well for the fender.  $125.00
« Reply #27 on: March 21, 2016, 07:38:19 PM »
Check the width of the well, its less than 5" and not a lot fits into it.
mike       8)
« Reply #28 on: March 21, 2016, 10:44:01 PM »
If one of the little spares won't fit just use an old wheel & tire that will. You could use a cover if it was too ugly.
« Reply #29 on: March 22, 2016, 08:19:52 AM »
Yes, but I need a spare.  I think the one on EBay is 6 inches wide.
http://www.ebay.com/itm/Chevrolet-Chevy-Running-Board-Fender-Spare-Tire-Well-STEEL-29-30-31-32-/350910012464?hash=item51b3dddc30:g:G9UAAOxyCepSausI&vxp=mtr
« Last Edit: March 22, 2016, 08:21:47 AM by munch »
