Author Topic: And the price goes up.  (Read 27671 times)
Re: And the price goes up.
« Reply #15 on: February 24, 2016, 09:57:05 PM »
Ghost, have you considered spraying the metal top with 3 M #888 rubberized undercoating, which gives a pebbly finish that's paintable.
Then using a semi flat  or satin paint, spray it.
That metal top looks excellent to me .
mike 8)
« Reply #16 on: February 25, 2016, 07:24:03 AM »
I was once told by a guy who did custom tops/upholstery, generally, he came up with his prices by taking the cost of materials and then doubling it for the price of labor. So, using this generalestimate, if the material cost about $100. the labor would be about $200. I suppose a more difficult job or special custom work would be more expensive but looking at your top I think $400. would be the max I would want to pay. Depends on how deep your pockets are and how desperate you are ;D
Ghost I've seen your work, I think you could do it yourself and in the end be much more satisfied and gratified!!
I like that frame your making too, it might be time to go into a sideline........
« Reply #17 on: February 25, 2016, 03:53:04 PM »
$600 is a damn good deal. Id take it.
That formula doesn't sound right.
« Reply #18 on: February 25, 2016, 06:43:50 PM »
  Ghost28  I was so taken aback by you getting screwed on this especially when you have told us lads here that you know how to sew.So weather is rain sleet and sluch today went to our mothly firefighters get together.When i got home i went streight down stairs and started rooting about 15 minutes ago i found what i used 30 years ago on my boat and roadster top.
  The book i am talking about is the second edition by Jim Grant the title of the book is The Complete Canvasworker's Guide:::How to Outfit your Boat with Fabric It has been the best that i have found and it worked perfectly for what i wanted.Also that HD Sewing machine for 150 bucks is It will in all probablility never be worth anything less.
  I would go to your local Library and or book store and inquire about this book   vette59jdwl
« Reply #19 on: February 25, 2016, 09:39:53 PM »
mike 8)
Thanks, but the pictures make it look better than it is. It would need a good padding and then some kind of top material before it would look right
 I did finish the folding top mechanism and it works great. Now on to the header board, and the rear piece that the top material will snap to, then take it all apart and paint it up real nice before covering it, shich I will try to do myself with some library help. Man I hate study hall.
« Reply #20 on: February 26, 2016, 07:05:53 AM »
Nice work Ghost.  Didn't you skip study hall back in the day ;D
« Reply #21 on: February 26, 2016, 08:20:25 AM »
Go man go!  You are quite the M.E.  :)  I don't know if you've seen this youtube video, but here is the link. It lays out most of the steps (does skip over some).
http://youtu.be/NcejH6cJnAs
« Last Edit: February 26, 2016, 08:37:20 AM by sammons »
« Reply #22 on: February 26, 2016, 09:45:14 AM »
mike 8)
Outstanding Ghost, I wish I had your talent.  Great work...
« Reply #23 on: February 26, 2016, 04:02:17 PM »
Ghost 28 You are doing a bang up job.One question where you have the stantion the first part of the hinge job is that not supose to be on the inside and the folding top fold into the car between the quarter panel and the seat and fall into a well behind the seat,or are you going to have it sit up something like a Pheaton.  vette59jdwl
« Reply #24 on: February 26, 2016, 09:06:45 PM »
There is not enough room for the top to go into a pocket unless I hinge a pocket out of the body like a early 60s corvette. This one will sit up like it was when new to give it that old car look like a phaeton. They did make a aftermarket 32 ford body that the top folded into the trunk area. It is done except painting and canvas.
« Reply #25 on: February 26, 2016, 09:24:26 PM »
What can't you do???  Nice work :D
« Reply #26 on: February 26, 2016, 09:32:23 PM »
Ghost28  I think you will have to cut that header wood all the way across to give yourself a square starting point from which to work then put the peak back into the header. I do not see a problem except at the back where you are going to have to steam heat some kind of wooden material so that you can tack the end of the top.Having said that when you want to put the hardtop back on you may have to make another header for the hardtop does that sound about right.One piece of material on both sides all the way back to the back tack strip and then one piece down the middle to the last bow and make the back piece with the window in it so you could sew a zipper in that so you could have it in or out.your choice  vette59jdwl
« Reply #27 on: February 26, 2016, 09:34:39 PM »
You guys are too nice, but it's because of you fellas that I keep going on with my projects.
Thank You....John
« Reply #28 on: February 26, 2016, 09:52:44 PM »
I did cut 1  inch off the header on the long side and squared it up where it attaches to the mechanism. The curved front area is where the top canvas will tucked under and be secured. The hard top will not ever be used again, so I took the header from it, along with the curved metal tubing piece that already fits the shape and has the bolt holes drilled for bolting to the body this goes where you are talking about the steamed wood piece. I have drilled small holes every 4 inches on this tube to attach the male part of a snap that that the female part on the top material will snap. I like your ideas about the canvas layout, and the zippered back window.
« Last Edit: February 26, 2016, 09:55:17 PM by ghost28 »
« Reply #29 on: February 26, 2016, 10:43:52 PM »
Ghost28  I think madmike3434 has the most experience of anyone here with steaming and bending wood. He even has more experience with this than I do. but what i would do is do it in three pieces just like the top.I would measure it's total length with a piece of string then i would cut my center piece out about 6 inches shy of the curve then i would make both ends of that a dovetail.Then i would remeasure the whole length of the piece that i would want subtract that from the center piece and devided by two this figure should be the length of each corner piece.Being that this piece should be about 18 to 23 inches in length It would be easier to bend.I think i would make a block and bend it using steam and keep bending till you get the shape you want then dovetail the one end so it would fit in the end of the middle piece, then do that to the opposite end and bolt that into the rear deck of the car. vette59jdwl
