Author Topic: Spindles for 34 chevy master 5 window coupe  (Read 6031 times)
Sparks58
« on: November 27, 2015, 05:48:08 PM »
This is all new for me. Restored classic Chevy's 55-67 for the past 15 years. But always wanted a 34 Chevy.
I now have a 34 Chevy master 5 window coupe. It has the knee action front suspension. I removed the king pins- spindles. Which are attached to the knee action. I was hoping that I could find some stock spindles to replace. And try to use the same bolt in support cross member. I'm on a budget did not want to go straight axel/mustang ect. Need some insight-education on how to go about this. One question is can I use a standard front set up? If so where can I find? And could I use later model Chevy spindles?  Or possibly have my cross member machined to accommodate a new king pin / spindle set up.
I'm ok with a drum set instead of disc for the front.
Thanks Jim  913-515-9515
Jim
Re: Spindles for 34 chevy master 5 window coupe
« Reply #1 on: November 27, 2015, 06:10:55 PM »
Welcome Jim...I'm sure the right person will jump in shortly to help you (it's not me).
Sparks58
« Reply #2 on: November 27, 2015, 06:16:14 PM »
Was not sure if this was the right spot to post this question? Is there another location to list for more exposure?
Jim
« Reply #3 on: November 27, 2015, 06:16:34 PM »
Welcome from the other side of the state Sparks!
I don't know what would fit, Madmike may have a good idea on stock suspension. Long shot, If you knew someone down around Chetopa ks.(about 130 miles due south of you) their use to be an old boy that had a lot of 33-35 Chevy parts. He died years back but i can't remember who was handeling his estate. They may be gone by now, fella told me 3yrs ago there were still parts left?
                                                      Sammons
Sparks, i found this on Hemmings Motor News. Looks like spindels are interchangeable on '34 Master with 34-38. Hope that helps.
Maybe someone can post this link. Interesting artical with interchangabilitiy of Chevrolet spindels from '28-'90.
« Last Edit: November 27, 2015, 09:01:47 PM by sammons »
« Reply #4 on: November 27, 2015, 09:16:44 PM »
Sparks,
Don't have the answer to your question but welcome to the forum.
Sparks58
« Reply #5 on: November 27, 2015, 10:38:01 PM »
Thanks EDNY, Sammons, and TFoch for the welcome and information. Looking for a possible interior wood kit. Most likely will end up with steel framing.
Jim
