Author Topic: Methyl Ethyl Ketone (AKA M.E.K.)  (Read 4405 times)
« on: November 08, 2015, 10:48:14 AM »
My son just turned me onto Methyl Ethyl Ketone (AKA M.E.K.) for cleaning oxidized aluminum parts.  Just bought a 1992 Camaro 350 TPI engine that sat outside under a tarp. It has that white crusty oxidation on the aluminum fuel injection parts.
In the past I would scrub with a wire brush to get the parts cleaned up...which took a bunch of time/labor.  Just bought a can of the MEK and put a little on the TPI plenum then used a small stainless wire brush to work it into the crusty surface.  In very liitle time and effort the plenum cleaned up nicely..need a smaller brush to get into the grooves.
Attached a picture after the scrub..wish I would have taken a picture before I started.  Really works great..BUT you need to do it in a well ventilated area :o
Re: Methyl Ethyl Ketone (AKA M.E.K.)
« Reply #1 on: November 08, 2015, 01:11:48 PM »
Ed your right ..The stuff does work great but according to some studies is potently very toxic. My guys in the body shop used to use it but OSHA rules proved tough to comply with. One thing for sure,wear a respirator even in a well ventilated area.
« Reply #2 on: November 08, 2015, 01:34:53 PM »
Ed  tread lightly::::
Methyl Ethyl Ketone
CLOSE ALL
What are other names or identifying information for methyl ethyl ketone?
CAS Registry No.: 78-93-3
Other Names: MEK, 2-Butanone, Methyl acetone
Main Uses: Solvent, chemical intermediate
Appearance: Clear colourless volatile liquid.
Odour: Sweet
Canadian TDG: UN1193
What is the WHMIS 1988 classification?
B2 - Flammable Liquid; D2B - Toxic (Eye irritant)
Symbol for Class B
Class B2
Symbol for Class D2
Class D2B
What are the most important things to know about methyl ethyl ketone in an emergency?
Emergency Overview: Clear colourless volatile liquid. Sweet odour. HIGHLY FLAMMABLE LIQUID AND VAPOUR. Distant ignition and flashback are possible. May cause drowsiness and dizziness. IRRITANT. Causes moderate or severe eye irritation. ASPIRATION hazard. May be harmful if swallowed and enters airways.
What are the potential health effects of methyl ethyl ketone?
Main Routes of Exposure: Inhalation. Skin contact. Eye contact.
Inhalation: Can irritate the nose and throat. At high concentrations: can harm the nervous system. Symptoms may include headache, nausea, dizziness, drowsiness and confusion. A severe exposure can cause unconsciousness.
