Author Topic: Running board height sedan?  (Read 11545 times)
« on: March 10, 2015, 11:31:30 AM »
62131 and others
What is your running board height?  Setting up my son's 37 (4) door sedan front/rear suspension and right now have it mocked at approx 8" to 8.5" from the ground to the bottom of the running board.  Looks like good tire clearance so far?
Re: Running board height sedan?
« Reply #1 on: March 10, 2015, 06:49:20 PM »
Ed I wish I could answer your question but I have my car up on jack stands right now putting tubular a-arms on it. I was running the standard mustang II arms and brakes. I wanted to narrow up the front end so that could run 11" drilled and slotted rotors. I changed the front rims from 14" to 15", the 14"s would not fit over my calibers. Hopefully I will have it back on the ground soon, springs coming. If anybody is interested in some stock mustang II front end parts let me know as I will make them a deal.
« Last Edit: March 10, 2015, 07:03:11 PM by 62131 »
« Reply #2 on: March 10, 2015, 07:33:11 PM »
My buddy just replaced the entire frame under his 39 sedan because he didn't like the handling of the car. It had a Camaro or Nova front suspension grafted in.
On the replacement frame he welded in a Mustang II and used 2" drop spindles...now it's too low. He already ordered a new set of standard spindles.
« Reply #3 on: March 10, 2015, 08:38:51 PM »
I'm using the stock spindles, I have a Heidt cross member that was already welded in, the person I bought the car from used stock mustang II arms and spindles and brakes. I knew that the 2" drop spindles would set the car to low. I want to get away from the strut rods running back to the frame.
« Reply #4 on: March 10, 2015, 08:41:02 PM »
What type of arms is he going to use?
« Reply #5 on: March 10, 2015, 10:54:15 PM »
He buys all of his stuff from Yogi's so what ever they sell...but the arms are round tube and is using coil overs.
I'm sure you know that you can drill out the cross member and weld in the (1" diameter) control arm bars and gussets so you can use the wide lower arms?
« Last Edit: March 10, 2015, 10:56:22 PM by EDNY »
« Reply #6 on: March 11, 2015, 08:53:35 AM »
62131 and others
That sounds like good clearance. I usually set mine so I't can barely knock over a beer can.  ;D
« Reply #7 on: March 11, 2015, 12:47:39 PM »
[/quote]That sounds like good clearance. I usually set mine so I't can barely knock over a beer can.  ;D
[/quote]
That sounds like a waste of good beer! :(
« Reply #8 on: March 11, 2015, 12:57:05 PM »
12 or 16 ounce can?   ;D
« Reply #9 on: March 11, 2015, 08:32:08 PM »
12 oz, empty can. No waste here.
« Reply #10 on: March 11, 2015, 09:17:48 PM »
yep can't waste that stuff ;)
