Author Topic: Can anyone ID this circuit board part?  (Read 7030 times)
« on: December 27, 2014, 03:18:09 PM »
Can anyone ID this adjustable switch? It's the one on the far right and looks to have the number E05, the other two on the left have part number 205. All three are attached to the mainboard with (3) soldered pins.
It's for the controller board of a mini lathe....just need to know what it is called so I can order one.  I know it's bad because when I tap on it..the lathe works. (Already replaced the relays)
Re: Can anyone ID this circuit board part?
« Reply #1 on: December 27, 2014, 05:53:33 PM »
I believe what you have is a adjustable resistor value unknown, if it works when you tap on it I would check the solder joint first then the component.
« Reply #2 on: December 27, 2014, 06:16:59 PM »
This should work Ed...
Click to view
 Or more expensive on Amazon
Click here
« Last Edit: December 27, 2014, 06:27:23 PM by themoose »
« Reply #3 on: December 27, 2014, 07:11:10 PM »
Thanks Moose....I need to locate the schematic to determine the size....found some on eBay, this one auction shows a couple of them beginning with the letter E...so maybe the one I need is E05....but I'll look it over again.
http://www.ebay.com/itm/13-Valuex5pcs-65pcs-Variable-Resistors-Potentiometer-Assorted-100ohm-1M-Kit-/351265473667?pt=LH_DefaultDomain_0&hash=item51c90dc483
Now that I know what they are called..I'll try to narrow down the proper resistance.
« Reply #4 on: December 27, 2014, 07:16:56 PM »
Ed...I believe that the one you show in the picture is numbered 205 which is its rating.Thats why I pointed you to the ones that I did.
« Reply #5 on: December 27, 2014, 07:35:30 PM »
Looks like E05 for the one on the right..maybe this picture is better?
« Reply #6 on: December 27, 2014, 07:39:41 PM »
Moose..If I turn the picture upside down...could be:  503 and the other two: 502
« Reply #7 on: December 27, 2014, 08:49:30 PM »
Moose...looks like it is 503..I located them on eBay...Good News..they have them. Bad News need to buy -10-, Good News they are Cheap, Bad News..I'll have -9- in my tool box until the day I die!
http://www.ebay.com/itm/10Pcs-3362P-1-503-3362-P-50k-ohm-High-Precision-Variable-Resistor-Potentiometer-/371163919412?pt=LH_DefaultDomain_0&hash=item566b17f434
« Reply #8 on: December 27, 2014, 08:56:14 PM »
Ed I agree that that's the number...I bet I know where I can get one cheap if I need one.. ;D
« Reply #9 on: December 28, 2014, 10:07:11 AM »
You might want to try Newark Electronic web sight.
« Reply #10 on: December 28, 2014, 11:27:33 AM »
I'm good to go...ordered them last night.
