Author Topic: Sway Bar(s) yes/no?  (Read 11238 times)
Sway Bar(s) yes/no?
« on: December 04, 2014, 08:55:36 AM »
Never thought much about it...but I don't have sway bars on my 34 Coupe, leafs rear, Mustang 2 up front and I'm happy with the way it handles, but I'm not burning up the streets.
On my 33 Coupe project I have a four link rear and Mustang 2 up front. Think a sway bar up front would be worth the effort? I could fabricate one that mounts behind the cross member.
Re: Sway Bar(s) yes/no?
« Reply #1 on: December 04, 2014, 09:34:33 AM »
Ed I don't know about others, but I have found that weight and how hard you are driving makes the decision for me. I aways run a front one, (7/8" on my coupe)  I'm going to see how it handels before running the rear. I've tried to move my weight towards the center of the car and being lite I might not need the rear one.
« Reply #2 on: December 04, 2014, 09:59:24 AM »
On my 1935 Chevrolet standard 3 w coupe I have a kugel IFS with supplied sway bar.  In the rear I have a jaguar IRS with factory XKE 4 coil over shocks.  Every time I went around a corner,  right turn, the body would lean into the left side fender well.  And same on other side when turning left.  You would think the 4 coil over shocks would control it, NOT !
I bought a 35" wide SCHROEDER sway bar .800 thickness with aluminum arms and mounted it behind the rear end.   You can find these used from nascar teams selling off older equipment very reasonable.  They come from 1/2" thick to 7/8" ......and the splined ends are 15/16 " .  Very slick setup.
If I was running a leaf spring rear it would be fairly simple install with a 24--28" sway bar, 2 pillow blocks with oil lite bearings , a cross member to hold it, a couple of mounting tabs on the rear end housing.
Does it work..............I have 3/4" between my rear tire and inside quarter panel, has not rubbed since.
mike           8)
« Reply #3 on: December 04, 2014, 10:22:12 AM »
Ed, I have nothing on my car now and I am running leafs in the front and rear. However, to me it is a "no-brainer", and is an upgrade that I hope to make in the near future. So, I say yes, you just have to find the right system for your car, and that may be the toughest part.
« Reply #4 on: December 04, 2014, 11:02:01 AM »
A guy named gene vrendenburg of the LA roadsters had a feature done on his 33 cabriolet using stock suspension leafs on front. Car was on cover of ROD ACTION MAGAZINE ....YEAR UNKNOWNI noticed he had a sway bar mounted behind or in front ??? of the axle, I forget.  The sway bar was straight and the pillow mounting blocks were bolted directly under the frame and attached to the front axle by spherical rod ends and splined arms.  Here is a link to an auction on ebay, I think magazine is overpriced by $13.00, but here it gives you the year 1973 and month december that it was printed so when you go to a swap meet you can more easily find one.
http://www.ebay.com/itm/Rod-Action-Magazine-December-1973-The-Cheverolet-Story-on-Cover-1012E-/330630954803?pt=Magazines&hash=item4cfb23ff33
mike 8)
« Last Edit: December 04, 2014, 09:25:02 PM by madmike3434 »
« Reply #5 on: December 04, 2014, 11:15:28 AM »
Thanks, Mike, it's something for me to look into.
« Reply #6 on: December 04, 2014, 11:36:19 AM »
I have plenty of sway bars around here and setting up one up front would be the easiest....not sure if I even have any room for a rear bar on the four-link.
Have my engine positioned behind the front cross member about 4" further than my 34 coupe....stretched the wheelbase and set the engine back..hoping for better weight distribution.  Have the driveline as low as I can go and figure with at least one sway bar should stay glued to the road better?
I have a C3 Vette 7/8" sway bar that looks like an easy mount from behind the front cross member.
« Reply #7 on: December 04, 2014, 12:02:00 PM »
Ed your real close to my set up, my head sits 12" behind the ball joint. I wish I was to the point of being able to tell you how or if needed. I think the more weight above the front balljoint, the more it's going to lean in the corner?  My first '59 Elky would drag the side pipes turning a fast U Turn. My last one (frt and rear bars) was very stabil. Worked wonders on my '57 also, felt more like a Camero in the corners.
« Reply #8 on: December 05, 2014, 07:25:35 AM »
I have leaf springs in the rear and a mustang II up front, it's to early to tell if a set of sway bars are needed, I guess it all depends on the way you drive your car?
« Reply #9 on: December 05, 2014, 07:40:11 AM »
Your setup is the same as in my 34 3W coupe which handles just fine for my driving. I just like cruising and stay off the  state highways whenever possible.  Those big fenders and flat windshield probably weren't intended to go 65MPH for any length of time back in 1934?
« Reply #10 on: December 05, 2014, 08:33:36 AM »
mike 8)
[/quote]
Thanks, Mike, I am going to make a reasonable offer on the magazine and see what happens. If not, I'll keep an eye out. Thanks again.           Jim
« Reply #11 on: December 06, 2014, 10:33:10 PM »
Ed,
I have the TCI coil over in the front and leaf springs in the rear.  My friend at New England Rod shop recommended I use a sway bar up front when I ordered my front end.  I don't have a sway bar in the rear of the car.  I'm real happy with the way the car handles.  I can go down the interstate at 70 mph and it goes straight as an arrow.  If I take the back roads that are nice and twisty it sticks like glue.  I couldn't be happier with the way my car drives.
« Last Edit: December 06, 2014, 10:58:25 PM by TFoch »
« Reply #12 on: December 07, 2014, 07:36:51 AM »
The picture of your rear mounted front sway bar is what got me thinking about using one on mine. Gathering parts right now.
« Reply #13 on: December 09, 2014, 09:07:13 PM »
mike 8)
AMike, a quick search on ebay, and I bought one for $8.00. Now, let's see what 1973 technology gets you.
« Reply #14 on: December 12, 2014, 04:20:51 PM »
prices on ebay are all over the place, pick your price point and wait till what you want shows up...................unless you got $$$$$ out the wazoo
mike           8)
