Author Topic: Wanted: 1933 Chevy Tail Light Arm  (Read 31180 times)
Re: Wanted: 1933 Chevy Tail Light Arm
« Reply #15 on: February 03, 2013, 08:37:41 PM »
I just mailed a Rusty Bowtie business card to him.
Coley
  • colemang@myyahoo.com
« Reply #16 on: February 15, 2013, 12:39:37 AM »
Thanks form the invite to this website.
I make the tail lamp stands and I used to make the buckets also.
I could cast them in ZA alloy as thin as the steel stamped ones.
Lost all the tooling in my fire. Am trying to figure out how I can do them again as I need some also.
I just am too old to go into lost wax investment casting again.
There are a lot of cars out there with my ZA lights on them.
  Changed the name of my shop from CHEVY to Chevi because of the GM lawsuits.
I also made trademark nameplates for Cameos and such, but had to stop  that, as well.
I really like the site.
Greg Coleman
Chevi Shop Custom Casting
« Reply #17 on: February 15, 2013, 07:15:36 AM »
Greg,
Glad you like the site.  Lots of really good people on here.  I enjoy the casting post you've done so far.
« Reply #18 on: February 23, 2013, 08:34:06 AM »
Greg,
What would you need to make some new molds? I do 3D Cad for work if that would help. If you have someone that could make molds from 3D models maybe I could help.
« Reply #19 on: November 05, 2013, 12:14:42 PM »
I'm thinking these might look better on my 32 than the stockers. I haven't drilled the fenders yet so I'm looking for some.
I'm thinking the speedway ones may be able to be ground to fit the fenders.
Any ideas?
« Reply #20 on: November 05, 2013, 02:43:53 PM »
Any ideas?
Not trying to sway you...just responding as a FYI.  Don't know what tail light you want to run, ie Chevy, Ford etc.,  but in my earlier post I have pictures of my Speedway stainless 55-59 Chevy LED truck lights mounted on 33/34 Ford fender horns.  They fit each other nicely, they also sell a stubby 33/34 Ford horn that would look nice with the 55-59 Chevy truck lights.
I personally like the lense size of the truck lights and the LED's are real bright. Between them and a LED third brake light in the rear window...the folks behind your car will see you!  The Speedway truck lights also come without LED.
Senior31
« Reply #21 on: November 05, 2013, 03:14:14 PM »
Not to derail this subject, but Ed I saw your post awhile ago and this is what I plan on doing on my 34.  I have been looking at the swap meets for a set of 34 Ford arms, but they are hard to come by here in the midwest.  I would like to find a set that I can chop myself.  I am concerned that the pre-chopped ones might be too short.  Guess I will keep looking!  :)
« Reply #22 on: November 05, 2013, 04:12:11 PM »
Good deal...FYI I had to remove the pressed in nuts inside the tail lights and spread the mounting hole spacing a tiny bit to fit the Ford horns.  Then I made a gasket from an old bicycle tube and installed it between the light and horn.
« Reply #23 on: November 05, 2013, 09:31:56 PM »
Hey Ed,
I like the look of the truck lights!
I have both stands for the 32 but was in the shop with my son and he said that I should do something else with the taillights. I like your solution.
I think the speedway ones may work best for me because I can grind them to fit the fender.
I do like the blue dots though.
Mike
« Reply #24 on: November 13, 2013, 09:14:53 AM »
Hey Ed,
I'm not sure what I'm going to do with the arms. I like the ones that you used, but am also thinking of taking 2" out of the stockers.
How flat is the mounting flange at the fender side? I like your lights but am thinking I would like to use the stock lights. Do you have a pic of where the light mounts?
Mike
« Reply #25 on: November 13, 2013, 09:48:20 AM »
Hey Mike
I saw the tape you had on the tail light arm so I figured that was what you were thinking of removing. I ran it through Photoshop to give you an idea of who it would look...
« Reply #26 on: November 13, 2013, 09:57:40 AM »
Hey thanks,
That was a great idea!
I'm not sure if I like that better or not. I hate to kill all the styling of the 32 that's why I'd like to keep the original lights.
Still other stuff to do...
Just looked again, I do like it
I think it's the bumper sitting out so far that's bothering me. I do have new bumpers  but need the backers. So maybe I'll have the spring shop make them so the bumpers are closer to the body.
« Last Edit: November 13, 2013, 10:01:03 AM by logride »
Coley
« Reply #27 on: December 16, 2013, 11:29:28 PM »
I am sure glad you liked the 1933 -34 stands.
I have been making them for many years, but got burned out about 13 years ago and just have been working on them again.  Shop Fire.
I make both sides for the 1933-34 all and 35 standard.
I am also making the 1935-36 short coupe stand for the RH side.
I am just now trying to get the molds done for the 1935-36 LH coupe, with the license stem.
I also have a cast tail light housing in the works for the 1935-36 stands. Hard to cast something that thin.
When I have parts going, I usually put them on eBay.
