Author Topic: Brazing Cast Iron  (Read 7654 times)
Brazing Cast Iron
« on: March 02, 2014, 10:30:53 AM »
 When I was growing up in rural Connecticut dairy farming was still how most of my neighbors made their living. When it came to maintaining their farm equipment they had learned how to be self sufficient through necessity. If a piece of machinery broke in the middle of planting or haying season they couldn’t afford to take the time to have someone come out to fix it so they became very proficient in putting things back together themselves. One of the things that always amazed me was how they seemed to be able to fix just about anything with an acetylene torch. They could heat and bend steel back into shape, cut a new piece to size and then weld things back together and be off and running again in no time flat. One of the more difficult skills was the repairing of cast iron which they did often and very successfully. Most people are afraid to tackle such a repair and opt to just replace the part. If you have the time and money that’s most likely the best way but that’s not always possible. If you have a broken ear or cracked block or head on your rare next to impossible to replace engine you might have no choice but to attempt a repair. I happen to find this old article those talks about how to braze or as the article calls it “Bronze Weld” cracked cylinder blocks. I thought it was interesting and might be a skill worth adding to your arsenal just in case.  Moose
Re: Brazing Cast Iron
« Reply #1 on: March 06, 2014, 01:44:46 PM »
moose...I've seen similar info before to what you have posted above, but I have a question for you which falls in a similar vein.
I have a broken hub carrier from a '64 'Vette rear end in need of repair.  The missing pieces were long gone when I got the unit.  Do you know if it possible to build up some weld on such a piece, either with bronze or perhaps a specialized rod of some sort?
I'm attaching pics to show what needs to be fixed.
First pic shows the broken part...sorry about the out of focus.
Second pic shows it with the bar sitting in place.  It would be held on with a mega bolt if the broken part can be repaired.
Third pic shows what the former owner did to the other side...he welded in that short piece of pipe.  I guess his plan was to use one of the newer type rods which go right around the whole assembly.
And the last pic shows the whole piece so you have some idea what the heck I'm talking about.
« Reply #2 on: March 07, 2014, 09:01:08 AM »
From what I remember they are made of nodular iron. When welding this form of cast iron the formation of martensite lowers the ductility of the iron and makes it easier for cracks to start.  I think this is occurs in welding of many types of castings, but the formation of martensite seems to be a bigger problem in nodular iron. It can be done but I don't think its worth taking a chance on a suspension component.
« Reply #3 on: March 07, 2014, 12:07:38 PM »
Fair enough.  I think a replacement part is less than $100...so new it will be.  And many thanks for the information.
Coley
  • colemang@myyahoo.com
« Reply #4 on: March 10, 2014, 11:24:00 PM »
Interesting article.  One question I have is that they call it "brazing", brazing uses brass rod and not bronze, or am I missing something?
« Reply #5 on: March 11, 2014, 09:06:08 AM »
Coley
To answer question ..The term "Brazing" is a process of joining two pieces of material using a filler material such as brass but not exclusive to brass. Brazing and Braze welding are terms that are often used interchangeably and the equipment required to do the job is essentially the same even though the process is slightly different. In the article it clearly states "Bronze" filler. The whole point of the post is to inform people that there are processes available to them that will allow them to repair damaged castings. Here is the actual definition of the word Brazing.
"Brazing is a metal-joining process whereby a filler metal is heated above melting point and distributed between two or more close-fitting parts by capillary action. The filler metal is brought slightly above its melting (liquidus) temperature while protected by a suitable atmosphere, usually a flux. It then flows over the base metal (known as wetting) and is then cooled to join the workpieces together.[1] It is similar to soldering, except the temperatures used to melt the filler metal are higher for brazing."
Below is a link that might add some clarity to the issue.
http://www.technologystudent.com/equip_flsh/acet6.html
« Last Edit: March 15, 2014, 08:30:57 AM by themoose »
Chevs of the 40s Parts
Hamby Motors Vintage Parts SC
JULIANOS HOT ROD PARTS
TECH LINKS REFERENCE & MISC
DAVE's Small-Body HEIs
