General Discussion - Intros
That time of year
3
4
Topic: That time of year (Read 74133 times)
Re: That time of year
Reply #30 on:
May 27, 2025, 02:11:12 PM »
Looks great from here! A useable piece of equipment, good job!
Master
Reply #31 on:
May 28, 2025, 03:52:25 PM »
Yes, that looks really good!
Reply #32 on:
June 01, 2025, 10:54:31 PM »
Lol "Houston... we have a problem". The 4" of rain we had this week done her in. l started digging the tunnel in 1983 collapsed about 7 feet long out of the 15' running length. I noticed a couple years ago that the water coming of the nieghbors round top had started to run under my deckagon grainery, last year i could see under it was going down the 15' deep main shaft. Put it on my mental things to do list. I relaced all the timbers in '98, the hard clay down there was still perfect. Haven't looked down there since 2007?
Saturday morning i had a hole about 3' outside the grainery. I called Tom and he happened to have about 7 yrds of dirt on his '58 Viking so he dumped that out lastnight. Came over about noon with his Case "Construction King" backhoe/loader. Not near enough dirt to do the job. I started throwing tire/wheel combos down the main shaft while he made a quick sand damn in the creek bed and started moving sand up. Put 8+ yards in, pushed down worked around and got all except the last 3' out of 15'. It was hard as a rock on the northend where the water hadn't got. Pushed a bit of sand into it, tamped everything down with the backhoe then the dirt and packed it. 15 yards of fill, problem solved
Last Edit: June 01, 2025, 11:09:27 PM by sammons
Reply #33 on:
December 30, 2025, 11:30:47 AM »
With the chassis swap on my old mower complete, i started cleaning things up. Got a quick buff on paint, still have to wax it up. Decided that all the black plastic stuff needed dyed. No matter what i put on it, (Back to Black, vinyl dressing, silicon, etc), nothing lasted more than a week and back to fade. So i pulled them off, scrubbed it all and dyed it with Duplicolor's vinyl/fabric dye. Much better, hope it lasts a while. With a white paint pen i actually got the numbers painted back on. Don't know if it'll last but sure looked better. Got my new Marylin Monroe steering wheel knob on the fresh refinished steering wheel😁
Last Edit: December 30, 2025, 11:35:56 AM by sammons
Reply #34 on:
December 30, 2025, 07:13:30 PM »
Looking great!
Reply #35 on:
December 31, 2025, 09:28:05 AM »
Gonna be nice this spring to mow with everything on the chassis tight again. The steering was severely worn, hard to turn and wondering and to mention front spindles bent. The deck lift arm was shot also. Donor was a fairly low hour one. Now i'll have to finish putting donor back together, it will just pull my trailer.
Reply #36 on:
January 15, 2026, 06:50:47 AM »
Three stepps forward..... 😡 I had the mower all back together. I thought i'd better get some gas and fire it up since the weather was warm enough to open the windows to check it out. Turn key to on heard the usual kick of carb solenoid, then to start.... nothing. Checked battery again for full charge, 12.7v. First thought was ign switch may not have gotten plugged in all the way. When we did the chassis swap, i swapped in my V-Twin, my wiring harness. I did not swap out my ign switch, or any of the safety switches. Started with ign switch, even cleaned it first and all the connections with a brush and electronic clearner. Nope nothing. Now i have to check all the safetys. I'll have to pull the deck back out to get to the brake/clutch safety, pull the battery, tray and support to get to the blade safety etc. Looked on youtube for ideas, several guys are checking all by cutting the mag/coil wire to ign to check for continuity between all switches with the "beep" function. Had to pull top cover to verify the coil wires, still not testing out.
Seems like the doner mower was running, but the farmer had cut and bypassed all the safetys. I'm guessing he had a bad one now. Sure wish i would have thought of that first while doing the swap🙄
Had to bail on it to go to my new Dr. Had to find another as my buddy retired. Guess he was 6mo older than me. So i had to re up everything and transfer all records etc last month. Get all nrw blood tests for comparison to last years. Went in to get my test results etc, new Doc says all ok and that they verified Rheumatoid Arthritis, and laughed, i said really😁 Then i asked what my rheumatoid factor number was now... 18yrs ago it was 458, normal people are +/- 15. My new number 650. I told her i kinda feel like its that high😅 Anyway all good just a click or two up on A1c from me trying to gain weight over the last 14 months. She said i could stop now and lay off the fatty stuff . I did gain 26lbs.
Now... back to the mower today, maybe!
Reply #37 on:
July 15, 2026, 09:29:15 PM »
I was out this morn trying to beat the heat with my old walk behind edger. Did part of my neighbors drive way and busted another plastic wheel center. Just replaced on 2yrs ago. Noticed fronts are cracked in the centers. Talking to neighbor after dinner tonight, told him i was gonna do more but...
He asked what size because when he sold his parts store he had a bunch of NOS old ones in back that he had moved to the round top behind me. We walked over and found the pile. Picked up two 7" fronts and two 8" rears. He said they were stocked in the 50s or 60s. These are steel wheels with rear bearings and solid rubber tires. He says hell, just take them. I tried to pay him, nope.
They will darn sure out live the machine. Tomorrow project, they have 1/2" center hole, mine are probably 7/16" or possibly 3/8". Thats ok, i have brass shim stock if i need it😁
Looks like he'll get more edged. He has one, but it doesn"t work that well. He usually just weed wacks the side walks.
My edger has enough power to whisle thru. I cut down my old mower blades to use on mine. They will do 1 or 2 seasons instead of 4 edgings with the factory cheesy blades.
Last Edit: July 15, 2026, 09:38:58 PM by sammons
Reply #38 on:
July 15, 2026, 11:02:13 PM »
Yep! That time of year. My friend and I have been clearing years of willows from around my springs and water tanks. I thought I was filling my pond but a leak developed when it was a foot from the overflow. I'm dumping 1700-2000 gallons a day into it and I'm loosing ground. Don't know what to do about the thousands of tadpoles that showed up while I was trying to fill it. The water must have found some roots or a way back to the aquifer. I can't see it anywhere. I need goats, lots of goats!
Reply #39 on:
July 16, 2026, 09:09:23 AM »
Sorry your having pond problems. When my brother was having his pond cleared of cat tails they hit his water line that fed it from the windmill. Had a heck of a time gluing it back together as it was below later level.
My uncles place had two big buffalo wallows that always held water from rain/field runoff. He decided to dig a pond there. Dug and packed it with betonite. He tried to get a local rancher to bring cattle in to pack it good, but the guy said he couldn't as it would be putting too much nitrates in the ground and the liability becaude of his well water. It never held water.
Last Edit: July 16, 2026, 09:16:22 AM by sammons
Reply #40 on:
July 16, 2026, 01:18:25 PM »
Got rear wheels replaced this morn and edger serviced. They went right on, they were 1/2" center hole. They used a shoulder bolt, looks like fronts are similar, but not sure how axle comes out yet. Decided to get my neighbors sidwalks and drive done while it was cooler. Also he couldn't object, they went to Dodge to get theirJeep windshield replaced😁 Breezed right thru it. Sure rolls easy with real bearings👍
Reply #41 on:
July 16, 2026, 06:34:54 PM »
Nice to get parts when they were built to last!
Reply #42 on:
July 17, 2026, 03:20:16 PM »
Ah shoot, my buddy Tom was bidding on an online auction site for another HD 3500. He bought a 1996 Chevy several years ago to retrofit the drive train, (front axel disc brakes, rear axle, tires/wheels etc) on his old 1958 Chev C60 Viking wheat truck. This past week he's been waiting out the bidding, he didn't miss it by much. He quit at $850 plus 10%, plus tax, plus 60-80 gal diesel fuel to go up to Grand Island Nebraska after it.
He wanted the extra tires/wheels, brakes spare rear diff and mainly was after the 5 speed overdrive manual trans w/ the old style emergency brake mounted on tail shaft.
Sold for $925 + 10% +tax.
Reply #43 on:
July 17, 2026, 03:39:16 PM »
Man i fought that stupid push cap wheel/axle lock for over an hour trying to get it off last night to replace front wheels. I needed to reuse it so was trying to save. I didn't know where i would find one and figured my luck it would have a hardened axle and would be hard to drill a hole for cotter pin.
Called Tom to see if he had any ideas or would stop by and give a hand later when he got home from work. He asked me what size axle, told him 1/2". Then he said guess what i just bought. I thought maybe the Hd3500 after all. The then sends me a pic of 3 push cap locks. Said i just picked me up one, and thought he might as well get an extra 2 pak just to have. What are the chances of that happening😁
Got here about 9:30 so i just cut it off with cutoff wheel. Got it all back together this morn and edged my curbing. Boy it really rolls easy across the grass to do that. Before i would basicly have to drag it. Yesterday i measured how much blade i used to edge my nieghbors place. Just about 800' of sidewalks, walkways and drive way. Just right at 1/4". Those factory blades i probably would have wore down at least 1 and 1/2 blades.
Reply #44 on:
July 22, 2026, 11:41:24 AM »
I haven't been able to run my chainsaw for 3-4 yrs. Didn't have the strength in my hands to hold it let alone pull trigger. Other than my brother coming back last couple years to clear stuff for me, it was getting out of control.
Last month i picked up a harbour freight cheap Bauer hand held 5" bar 20v chainsaw. Little dude does real good once i overide the safety switch. My brother just sent me another yesterday that he bought his wife, said it kicked butt for a cheapy off amazon. It came with an 8" bar and a 6", and a very handy left hand grip.
I've cut down a group of 10 small trees, 2" to 4" and the last this morn that was 8-9" diameter. Very impressed with both saws. I'm getting one heck of a big pile built up. Waiting for city to come pick up, after all, that creek area is city property. I've been cutting trees and mowing it for 44yrs, they can't complain.
3
4
That time of year
