1930 Buick V12 build
35
36
37
38
43
Topic: 1930 Buick V12 build (Read 587496 times)
Reply #525 on:
January 18, 2026, 05:46:24 AM »
There will be days like that, unfortunatly i have too mamy of these days lately😁 As the saying goes.... shi#! happens.
Honestly, i've ran on to that on a model A front fender. The guy jad picked up one NOS fender and a good used fender. The "swoop" was different, not much. Dad was laughing at me as i was fighting it trying to get it closer. He said hell son, you can"t see both sides at once🤪 That wasn't what i wanted to here. Difference, between stamping mills or maybe one was just tweeked from being old??
Keep at it, you'll get there.
Reply #526 on:
January 20, 2026, 02:21:55 PM »
Thank you
Tonight I welded what little was left to weld on the new fender edge.
Some grinding later, the weld bead was gone and I cut down the
oversize sheetmetal to get a view of the result.
Now it looks right, in other words, like I meant it to look, and
About the same as the other side.
I guess you might not even se the difference, but it looks ?bulkier?
as at least ten inches is more than 7/16ths wider than before.
Reply #527 on:
January 21, 2026, 02:26:29 PM »
Yup-yup, going slowly forward again, the new fender edge tacked to the fender.
The swoop and the "depth" of the side looks much better than the previous version.
Last Edit: January 24, 2026, 07:24:35 PM by Essex_29
Reply #528 on:
January 22, 2026, 06:47:47 AM »
Lol, forward is good! Looks like you got it on the run, now just the fun of welding her up. Looking great man! 👍
Reply #529 on:
January 22, 2026, 08:50:46 PM »
Nice finish on the metal work. Keep it up!
Reply #530 on:
January 27, 2026, 02:42:58 PM »
Thank you
and
Have patience with me, this is a blow-by-blow thing right
now, but I'm getting so frustrated with this endless work
on the fenders, I just HAVE to describe the smallest progress.
I got the inner fender edge done and tacked, after a bit of
rolling in the eglish wheel.
Then I continued with the joint between the apron and the fender.
Also the hump for when the wheel is turned and the edge around
the exhaust primaries.
I surprise myself with how difficult this is, since I already did it once.
I make a point of working on this every day to get it over with.
Yes, I'm a bit fed up.
I took the fender off the car tonight and started cutting and hammering.
Now it begun to be fun, so I quit so it will be fun and inspiring to go to
the garage and continue tomorrow.
Last Edit: January 31, 2026, 07:02:09 PM by Essex_29
Reply #531 on:
January 28, 2026, 05:40:48 AM »
Essex its hard not to get burnt out on a big project like yours. Weird how sometimes the first side is reasonably easy, and the second a bear, nothing seems to go as smooth as the other side did. Sometimes fab work goes backwards🫤
Keep at it!
Reply #532 on:
January 28, 2026, 02:52:31 PM »
Thank you
for the compassionate words.
It feels much better now that I have everything tacked.
Next night in the garage I have about 10 ft of tig weld to make
along all the tacked seams. I was right too, this was really fun,
To get it all cut, hammered and tacked.
Welding is always fun, looking forward to it.
Reply #533 on:
January 30, 2026, 06:27:27 AM »
Essex, i'm glad your enjoyment returned. I love watching sheetmetal go from Frankinstein's monster to Sleeping Beauty 🙂
Reply #534 on:
January 31, 2026, 02:36:47 PM »
Thanks,
It was fun once the parts were tacked together.
I didn't expect it to take this long to make the
second one, it's been exactly a month since I
started on this fender.
Now it's done anyway.
Last Edit: January 31, 2026, 07:00:42 PM by Essex_29
Reply #535 on:
February 08, 2026, 08:01:52 AM »
Very nice!
Reply #536 on:
February 09, 2026, 03:03:19 PM »
Thank you
After a few days of recovering from the shock of getting the front
fender done (read: family and chores), I continued with the right
hand side running board and its associated parts.
I cut out the parts I had made before and went to a shop
and used their big sheet metal brake to get the running board
moldings done.
I bent the molding to fit the cut down to size runningboard.
This made the sideview feel more finished, since the front fender
seems to continue along the runningboard.
I then made a press tool to make the last little piece that is missing
on the bottom of the rear fender. Pressed in the bench vice.
Made a 1/4" round bar piece fit and welded and welded and sanded
Some cutting, welding and grinding later the result is pretty much
what I had envisioned.
Reply #537 on:
February 10, 2026, 07:38:00 AM »
Looks great Essex.
Reply #538 on:
February 15, 2026, 04:51:15 AM »
Thank you
I just had to try anf fix something that has bugged me for a while,
the front end of the bulges on the front fenders. Originally I thought
that they wouldn't be very visible, but as I got the headlights mounted
nice and low it didn?t look good.
Now the straight and angular shape is gone, and the new shape
Kinda follows the arch of the fender edge.
Last Edit: February 16, 2026, 03:16:44 AM by Essex_29
Reply #539 on:
February 15, 2026, 05:13:09 AM »
Learning by doing. I made the little bottom piece for the front of the left
Rear fender. This time the shape came out flawless with no hammer
marks. Fun when you can improve on work and results.
Simple improvement, I pressed the edge instead of hammering it.
The right hand side is kinda all done now. I welded a piece of flat bar
to the front inner edge of the rear fender. Then drilled holes
through the apron and the flat bar for three bolts.
I also made five small mounts along the runningboard for the molding
and got it all bolted together.
Small but visual progress, it's fun when you get things that shows done.
Now one side is all but ready for epoxy and bodywork.
Last Edit: February 16, 2026, 03:16:22 AM by Essex_29
35
36
37
38
43
