Author Topic: 1930 Buick V12 build  (Read 587450 times)
« Reply #510 on: December 15, 2025, 06:21:25 AM »
Essex, looking damn good! 👍  The detail in the sheet metal around the inner fender header and stuff like that i really notice. I've noticed most people never know what was custom built to make everything clear and look right. These custom builds take a lot of time to one personaly make you happy. It's worth it to me and peoole do usually like it, they just don't notice the little things that make it so. Keep it up, if you don't have a long pause between sides, its pretty easy to duplicate the other side🙂
My buddy that bought my coupe has been calling a lot. The car has been moved to its 3rd location now and pieces are being misplaced. Now he is trying on his own to put it together and finish up the drivers door which i never got around to getting the inner structire built, the door had been tweeked out of shape. Think hes on the right track. My memory has faded over the years since i did the passengers side, so thankfully i took a lot of pics to look and remember😁
« Reply #511 on: December 15, 2025, 05:45:53 PM »
Excellent work Essex_29!  The fenders with the headers running through them looks great!
« Reply #512 on: December 23, 2025, 08:52:51 AM »
Thank you all, and Merry Cristmas!
« Reply #513 on: December 26, 2025, 04:57:39 PM »
Thank you Rattiac I've always liked wide wheels and never got why
people shorten the axles instead of going with big arches  ~grinning~.
Yes sammons, not leaving it for too long helps a lot. Starting to work
on someone elses project, not knowing wherre to look for the parts in a ton
of bags and crates would be another level of hard.
Thank you TFoch. Inspired by those weird american quasi classics of the
eighties with the fake(?) exhausts coming out through the hood sides. I loved those.
I got my laser cut parts delivered home a few days ago. First one is mounted with acorn
nuts and all, this is all stainless, so it will be poished, and I think it will look good against
black paint surrounding the stainless header tubes
Since the fender is getting ready, I figured that it's time to think about the head light mounts
There was no way I could get them mounted as low as I wanted any other way than to make
mounts to put them at an angle.
These are the resulting mounts.
Here's my hand holding the head light bucket and mount in place. I chopped the mount a bit
after taking this pic.
Luckily the glass was easy to turn level, so now, if you  don't think about it, the heald light
looks normal.Just a few more things, and I get to start working on the other fender.
« Last Edit: December 26, 2025, 05:03:57 PM by Essex_29 »
« Reply #514 on: December 30, 2025, 11:05:41 AM »
Nice touch with the stainless trim and headlamp placement  👍
« Reply #515 on: January 03, 2026, 05:52:10 AM »
Thank you .
I started the new year off with welding the other head light mount
to the frame and hanging the right side fender in a somewhat
realistic position.
Now we get a first real look at what the front will look like.
« Reply #516 on: January 03, 2026, 05:25:36 PM »
Looks great man!  🙂
« Reply #517 on: January 05, 2026, 03:04:04 PM »
Thank you sammons.
Agonizingly slow work to get the other fender to sit the same
way as the first one. It's locked down lengthwise, and pretty
much sideways too.
I'm giving up for today, but tomorrow is a day off and I hope to
get the bow that holds the fender up done then. For now the
whole thing is held height wise with the box and 8 by 2.
Looks good so far, it's level for the moment being.
I have two exactly cut pieces of 2"x4" steel profile as jack stands
under the front cross member to keep it all level.
Keeps weld spatter and such away from the wheels too.
« Last Edit: January 10, 2026, 05:45:17 PM by Essex_29 »
« Reply #518 on: January 05, 2026, 06:54:02 PM »
Nice work!
« Reply #519 on: January 08, 2026, 11:40:45 PM »
I can not believe all the work you have done to make this right and how few people who see it will know it didn't come this way.
« Reply #520 on: January 10, 2026, 06:01:07 PM »
Thank yo both, TFoch and sixball.
I finally got the fender sitting like it should, it just took a couple tries.
After getting it ito position length- and width wise, I had to ?roll? it down
on the inside, making it stay on the outside.
I put the wheels back on today to check the spacing above the wheels to
allow for some suspension movement. It turned out to be okay, so on we go.
The springs are fairly stiff, the wheels hardly droop any when jacking the car up.
I took the whole fender bow off and  made it look pretty again, so now
you can?t really tell it?s been cut and welded every which way.
I started the repair and widening work today, going from the back forward.
« Reply #521 on: January 14, 2026, 02:42:28 PM »
I rolled the beads for the fender edges and running board
side moldings, with the help of a buddy. An electric bead
roller would be so useful.
The inner fender edge is beadrolled and the 1/4? round bar
is tacked in as per the first pic.
2nd pic shows the straightened outer fender edge held above
what will eventually be the running board parts that connect
the front- and rear fenders.
Beadrolling the outer fender edge made it look like a pringle chip
and took a good anount of shrinking and hammering to get reasonably straight.
Last two pics shows the long outer fender edge getting its
round bar tacked and all the associated vice grips, woodspacers
and clamps.
Also in the last pic the annoyingly short (60?) round bar is lengthened
with another piece.
Again clamps, hammering, adjusting and tacking.
« Last Edit: January 14, 2026, 02:45:48 PM by Essex_29 »
« Reply #522 on: January 15, 2026, 06:57:12 AM »
Looking good Essex.  Man that type fab work can be stressing, brain on constant up grade for a better way as your working to make it all come out the way you want. Your sure getting there!
« Reply #523 on: January 16, 2026, 09:18:47 AM »
Thanks for the pictures showing how you did it. A lot of work but nice results.
« Reply #524 on: January 17, 2026, 04:57:33 PM »
Thank you sammons and TFoch for the nice comments.
This is one of those days, though, when you find out that a few days of work were
more or less wasted.
I had been hammering the somewhat wonky fender edge, it was a smidge too wide
in a few places. I made a makeshift hammerform  that let me hammer down the bead
a bit. Then hammered more, shrunk some sjape into it on the shrinker, cut it all down
 and was about to start tacking the edge onto the fender? when I notidced that the
shape was a bit off.
First pic was snapped at thas stage.
I started measuring and indeed the swooping shape was wrong. I don?t know how this
happened, different shape (I was pretty certain that I had copied the other fender
edge with sharpie on sheet metal) or then the shape of the fendes themselves is
that different.
So i started over and the second pic shows the new fender edge. Tomorrow I might get
the edge bead rolled. Oh wel,l at least i get a lot of practice.
