Author Topic: Electric Fuel Pump Shut-Off  (Read 30046 times)
Re: Electric Fuel Pump Shut-Off
« Reply #15 on: February 11, 2017, 10:30:45 PM »
Attached the instructions for your EFI setup....looks like the blue wire Pin C is the wire you need to (switch) before it gets to the fuel pump.
Are you going to use the EFI to turn on cooling fans?
I wasn't planning on it, currently I have it on a temperature switch in the intake controlling the fan relay, also it's wired to come  on when I turn on the a/c
You should be fine that way..on my 94 Chevy truck with TPI I have a manual fan and don't even have an electric fan. Don't know if you have the 8 or 10 pin EFI but to have the fan come on via the ECM you would just need to remove the current intake switch wire and hook it up to the Pin C wire on the 10 pin connector - it (ECM) would then supply the ground the current relay you must already have. That's something you can consider once the car is up and running.  I assume you have a single speed electric fan.
Yes it's Spal 16" single speed fan
Looking at the diagram..you'll need to install their temp sending unit to control the ecm (open/closed loop).  If you decide to keep your existing fan setup...you'll need to install their supplied sending unit also.
« Reply #16 on: February 12, 2017, 08:25:07 AM »
I was planning on using the port on the passage side head to install that sending unit.
« Reply #17 on: February 12, 2017, 10:50:18 AM »
That'll work.
Bought a Honda motorcycle to part out and connected a very small LED to it's electric fuel pump...just to let me know when the pump was on while I was trying to start it after sitting in storage for years.  Maybe something to consider for your project..the LEDs are really small and draw minimal current..in a no start situation you would know whether or not the pump has power.
I put a small LED (1/4") on my dash of my 33 Chevy to let me know when the torque converter locks up. May just run one from the fuel pump also.
« Reply #18 on: February 12, 2017, 02:46:46 PM »
Quote
Ed , I'm assuming that Holley is using a heated wide band 02 sensor which should signal the ECM to go into closed loop well before the coolant sensor would. I wonder why they use the coolant sensor for this input.
« Reply #19 on: February 12, 2017, 04:18:51 PM »
Quote
From instructions looks like the self learning (air fuel ratio) doesn't kick in until the engine hits 160 degrees F.
« Reply #20 on: February 12, 2017, 05:48:16 PM »
Quote
 I guess because system isn't concerned about catalytic converter performance the PCM is controlling injector pulse width in open loop based on the criteria that is pre programmed  into the system when you run the setup procedure based on you engine and installed components such as displacement, camshaft ect. Once the coolant reaches the temp that you mentioned the system goes into closed loop and monitors real time data from the such as 02 sensor voltage, tps ,RPM and manifold vacuum to control fuel delivery rates with engine performance being the goal  rather than the controlling emissions  which are lowest at the stoichiometric ruel ratio of 14.7 to 1. A richer mixture will give better performance and run cooler so is a win/win on a performance engine. I never really looked at the Holley system in much detail before but it looks like a pretty simple and effective system. Now you’ve got my wheels turning….I wonder how the 32 would like a transplant.
« Reply #21 on: February 12, 2017, 10:41:16 PM »
Quote
That Holley EFI system appears to be first class, as you know the use of the wideband sensor versus the singleband sensor allows for really accurate air/fuel ratio adjustment (voltage range). My TPI engines only use the singleband one wire O2 sensor (non heated) so on cool days it can float from open to closed loop and the 1227730 ecm just can't make the precise fuel/air that the Holley system does.  I can always adapt a  3/4 wire up stream O2 sensor if need be, but I'm heading toward the LS family anyway.  The Holley EFI looks to be a well engineered system.
« Reply #22 on: February 13, 2017, 08:57:32 AM »
Ed...Can't you get your prom re-burned to possibly work better with your application?
« Reply #23 on: February 13, 2017, 11:15:28 AM »
Yes...I can do it myself..just need to wire in a wideband sensor and datalog..the problem is the car isn't on the road, maybe this year.  The 1227730 ecm works with the one volt O2 single wire sensor..the wideband sensors operate with five volt range. I just started flashing MEMCAL's and the OBD1 LT1 ecm's and having fun.
Have TPI in my 33 Chevy and 94 Chevy truck and burned both proms to disabled EGR, VATS etc. I have several bins from buddies with adjusted fuel trims and am using the Super AUJP bin.
Flashed a few LT1 ecm's also. What's neat about the LT1 is that you can go to FBODYTECH.com enter your engine data, gear ratio, driveline info etc and download a custom bin for free. It's works well, for my son's car I just changed the electric fan(s) kick on temps since we installed a 160 degree thermostat.
« Reply #24 on: February 13, 2017, 01:06:19 PM »
Well Ed , the way things are going these days maybe you should re-enable VATS ;)
« Reply #25 on: February 16, 2017, 09:07:58 PM »
Had to cut my new tank and install a flat recessed area on the top of the tank so that the fuel pump flange would set flat. The way the top of the tank is made there's not enough of a flat area to mount the pump flange flat. Hope to get it tig welded  tomorrow. I'll post pictures soon.
« Reply #26 on: February 16, 2017, 09:30:48 PM »
I have a feeling your're going to like that system...does that fuel pump unit have a return line built into it?
« Reply #27 on: February 16, 2017, 09:45:57 PM »
Yes it does, there's even a port for a vent fitting and a sump for the pre filter to set in to prevent starvation of the pump.
« Reply #28 on: February 18, 2017, 04:36:37 PM »
Here's some picture's of my tank with the new opening for the fuel pump.
« Last Edit: February 18, 2017, 04:44:05 PM by 62131 »
« Reply #29 on: February 18, 2017, 09:31:19 PM »
Just received my Car Craft (May 2017) magazine today..there is a write up on the Holley Sniper EFI (page 34). Didn't get a chance to read it yet....
Just noticed the story was also posted at:
http://www.hotrod.com/articles/test-holleys-new-sniper-efi/
« Last Edit: February 18, 2017, 09:33:48 PM by EDNY »
