Author Topic: water temperature sensor  (Read 12306 times)
Re: water temperature sensor
« Reply #15 on: August 05, 2016, 03:28:32 PM »
No problem glad to help...attached a picture of how I installed a return fuel line into the existing 37 Chevy sending unit. You need high pressure line from the pump to throttle body but not on the return line.
« Reply #16 on: August 05, 2016, 04:09:06 PM »
Thanks Ed, I will definitely let you know when I get it running.  Right now it is on the life because I am working out the 4 link.  I figure this would be a good time since there is no fuel in the system.  I drained the system when I put the Aeromotive Phantom in tank fuel pump.  I might as well finish.
