Author Topic: ID the year of this chassis?  (Read 6740 times)
« on: January 04, 2016, 08:34:10 AM »
As mentioned before I was kicking the idea around of making an "extended cab over engine" dually truck out of an early Chevy sedan.
Found this craigslist ad with a 34 Chevy sedan body already shortened.
http://syracuse.craigslist.org/cto/5355144564.html
The owner (Jeff) is not sure what year the chassis is....maybe 32?  Anyone recognized the chassis?
Re: ID the year of this chassis?
« Reply #1 on: January 04, 2016, 05:06:56 PM »
Ed i remember a few in the past  One fellow i knew did an old doge cab over and put the engine mid frame with a Jordan low boy slider on the back to haul his street rod  included are a few hints
« Reply #2 on: January 04, 2016, 06:02:51 PM »
Looks similar to my '32 chassis, Ed, but the panel above where the gas tank mounts is not the same, mine is solid.
« Reply #3 on: January 04, 2016, 06:13:19 PM »
The trouble with something like this 33/34/35 model is that in order to make a street rod cab over you have to raise the body and move it forwrd so that the doors will open and not hit the fenders  most cab overs if not all had the doors curved to meat the fenders. I think i will leave this one up to MOOSE he can do better than I  Moose please take picture 10 raise the cab and move the cab forward so that there is only about two feet between the windshield and the rad cap then make it into an extendacab and put a much newer box on the rear  I think that will put a smile on Ed's face. I have a picture in my head and i am sure you have the talent to do this  vette59jdwl
« Last Edit: January 04, 2016, 06:15:36 PM by vette59jdwl »
« Reply #4 on: January 04, 2016, 06:17:01 PM »
chopper526  I think it is probably a 34 chevy frame with a ford axle put under the front end   vette59jdwl
« Reply #5 on: January 04, 2016, 06:35:33 PM »
Actually I think the front lower corners of the doors would need to be trimmed to open around the fender...but that's on my version.
« Reply #6 on: January 04, 2016, 07:49:58 PM »
Ed  it sure would be ONE - of - KIND  vette59jdwl
« Reply #7 on: January 04, 2016, 11:29:36 PM »
Picture of the 34 (4dr) cut and joined.
