Author Topic: SHAZZBOTT a 1935 chevrolet standard roadster  (Read 47915 times)
Re: SHAZZBOTT a 1935 chevrolet standard roadster
« Reply #90 on: March 30, 2016, 02:09:21 PM »
the cowl panel was and is brutal.  Moisture got trapped under the metal top and the wood structure and caused it to rot out.  Not sure whether the mad bondo-ing was done in Argentina or Alabama.
The sides need serious repair on one side as it was bashed in an 1" or so and bondo filled, the other side needs the side mount arm hole filled, its a big 1 1/4 to 1 1/2 " hole.
Too make sure the curvature to the side of the panels match the door skins I took those up also to him as guides for fitting altering.
mike lynch    8)
« Reply #91 on: March 30, 2016, 02:32:26 PM »
Mike...Nice looking  and   excellent job  ..   very good skills  with the metal work
« Reply #92 on: March 30, 2016, 10:50:06 PM »
Sure looks like a pretty nice job especially considering what they had to work with.
« Reply #93 on: March 31, 2016, 12:05:54 AM »
same shop that did the rebuild of my 34-35 chevy gas tank cover panel.  I covered that 6 months ago in my SHAZZBOTT thread. They , Fawcetts Motor car co, have the skills , the tools and the old school machinery .
I am lucky to have a shop with these kind of skills right in my small town.
The adventure of re-doing this car continues
mike lynch     8)
« Reply #94 on: March 31, 2016, 07:29:31 AM »
looks great nice very nice job
« Reply #95 on: November 12, 2016, 09:18:29 PM »
SHAZZBOTT the adventure continues.
just came back from a friend MIKE CAMPBELL of blackstock Ontario who has a small milling machine.  Left my 34- 35 std roadster firewall cover plate in 1/4" thick aluminum there to be machined.
my 35 coupe has similar idea but its way to busy with a lot of ball milling done in mid 90's.  This one I want a specialized milling pattern I have never seen before.
 I had the firewall plate and the tops of 4 weber carbs air cleaner tops cut out of a 4 ft x 4 ft 1/4" thick T6061 aluminum, cut out using a super high pressure water jet cutter.
After a day or so of cleaning up the edges it will be off to the powder coater to have the parts coated in SATIN BLACK .
here is what I have so far.
mike       8)
« Reply #96 on: November 12, 2016, 09:22:43 PM »
a few more pictures
mike      8)
« Reply #97 on: November 12, 2016, 10:41:32 PM »
Wow..great idea....
« Reply #98 on: November 13, 2016, 08:04:14 PM »
hardest part is making the firewall pattern, especially the firewall indentation. Lots and lots of trimming the pattern .
If a place that does FLO JET water cutting is not close by..100 ?? miles, then I would look into having a LASER CUTTER used.
Not sure about a PLASMA CUTTER on aluminum ????  I do know that if your making a pattern for the plasma cutter, then you need to make the pattern 5/16" or so narrower so you get an exact fit.  Using 3/8 or 1/2 " MDF is a perfect FINAL pattern making material , to get a quality cut out.
mike  8)
« Reply #99 on: November 13, 2016, 11:09:49 PM »
I cut aluminum sheet with my plasma cutter..
« Reply #100 on: November 14, 2016, 01:15:06 AM »
CAN YOU CUT 1/4" OR 3/8"...?
« Reply #101 on: November 14, 2016, 07:18:38 AM »
Have been cutting 1/16" aluminum sheets and suspect that 1/4" or 3/8" wouldn't be a problem, but I'm using an Eastwood 40 Amp plasma unit not the 60 amp version.
Noticed that the aluminum cuts aren't as "crisp" as the steel cuts if you know what I mean. If you ever used a grinder on aluminum you know what I mean - because it's softer it peels over and creates a slag that needs to be removed.
« Last Edit: November 14, 2016, 07:22:51 AM by EDNY »
« Reply #102 on: November 14, 2016, 08:49:03 AM »
That looks great, madmike!!
« Reply #103 on: June 03, 2019, 07:34:58 PM »
have been neglectful on posting the goings on and progress on my 35 chevrolet roadster build called SHAZZBOTT.
The Tremec 6 speed, dual disc clutch, hydraulic throw out, scatter shield are all installed in my 35 chev std frame I had to open up in the X member.  Lots of creating strength back into that area.
Over last couple of months I have been playing with my vintage weber 48 IDF setup. Stripped white powder coating, bead blasted the 4 carbs and took a polished manifold and had it powder coated gloss black, carbs in satin black.  All AN hose is Russell black cloth and black anodized.  No more shiny braided stainless.
« Reply #104 on: June 03, 2019, 07:37:37 PM »
I made an adaptor plate to adapt the weber IDA carb air cleaner to weber IDF carb and intake.  Those aluminum air cleaners are super rare and only a pure stroke of luck allowed me to find them.
I also have the six inch velocity stacks powder coated black
