Author Topic: Clutch/Brake pedal assembly tear down question-'36 Standard Coupe  (Read 4969 times)
It looks like there may be a roll pin where my drift pin is pointing toward in the picture.  Is this the correct way to remove the brake pedal from the assembly while it is still on the car.....and is it possible to remove the clutch pedal with out removing the whole assembly.  I removed the clip at the drivers side of the assembly shaft but there isn't enough room to slide the clutch pedal out.
Chuck
