Author Topic: Undercoating, Sound Deadening  (Read 7486 times)
Re: Undercoating, Sound Deadening
« Reply #15 on: April 19, 2014, 10:19:16 PM »
 For the "browning" process used on muzzle loaders each gunsmith had their own formula but the result was controlled rust. That is my plan for the '53...control the rust ;D If I can seal the metal and deaden the sound at the same time that's good. 8)
« Reply #16 on: April 19, 2014, 10:27:06 PM »
Just don't "pee" on it!!!!!  Man my nose still hurts. Lol!!
« Reply #17 on: August 26, 2014, 07:29:09 AM »
I'm revisiting this topic as I'm still trying to decide what to put on my floor before the carpeting goes in this winter.  I saw on a show that they suggested using duct work insulation.  They said it was comparable to Dynamat but a lot less cost.  Summit Racing has a few brands, Thermo-Tec, Boom Mat, Vintage Air Dyna-Liner and their own Summit brand.  Let me know if you've used any of these and how you liked them.
« Reply #18 on: August 26, 2014, 11:03:50 AM »
Tom, here's what I used. Relatively cheap, seems to work good, no odor. It's been in my car for over a year, I haven't put in carpets or upholstery yet and like I said no odor. I used it on the floor and all other panels (inside doors, trunk, roof, cowl) with no failures. The only extra step I did, was I sprayed contact cement on the roof and vertical panels just to give me piece of mind. Also, I plan on using jute padding under the carpet.
Anyway, I don't know how well the expensive stuff works, but I like this stuff just fine.
 http://www.lowes.com/pd_154017-81326-PS625_0__?productId=1018733&Ntt=
« Reply #19 on: August 27, 2014, 07:30:55 AM »
Chopper, that brand seems to come up a lot and with good reviews.  So far I'm leaning that way.  Thanks
« Reply #20 on: August 27, 2014, 08:58:58 AM »
The comments posted below the item are pretty good!  Will be sure to try it.
« Reply #21 on: September 15, 2014, 09:13:00 PM »
The peal & seal I used was like $65.00 for a 36" x 100' roll freight was like $34.00, found my best deal on Amazon.com
Dugeman
« Reply #22 on: September 15, 2014, 10:17:25 PM »
I also used the Lowe's Peel and Seal and it works well on sound deadening . Can't beat the Lowe's price
