Author Topic: Adjusting turn signals  (Read 6114 times)
« on: April 01, 2014, 11:04:09 AM »
Attached is a picture on the inside of my steering column, the problem I am having is the left signal cuts off at the slightest touch.  Does anyone know how to adjust it?
Senior31
Re: Adjusting turn signals
« Reply #1 on: April 01, 2014, 11:54:16 AM »
Munch,
      Is that a flaming river column?  If so, the cancelling cam (black disc that goes on before the wheel hub) is just not in the right spot.  I had an issue with a steering wheel adapter hub I was using.  The hole for the horn wire was in the wrong spot and did not allow the cams to be in the correct location.  I believe the horn button wire needs to be in the 11 o'clock position if I remember correctly.  Once I elongated the hole and the cam was in the right spot no more issues.
« Reply #2 on: April 01, 2014, 12:03:26 PM »
Yes, it is suppose to be a Flamming River and I think I see what you are referring to.  I will send some more pictures.
« Reply #3 on: April 01, 2014, 12:33:08 PM »
This should help...It tells you how to index the canceling cam to the steering wheel adapter.
« Reply #4 on: April 01, 2014, 12:47:14 PM »
Thanks, it is all making sense now.  Sometimes I just need to be kick started...
« Reply #5 on: April 06, 2014, 02:19:24 PM »
Ok, took the advice and located the canceling cam as per diagram.  Now the left cancels and the right does not. I will play with it some more.
Now I am fighting the brake lights.  I have separate turn/brake lights and I know these were working.  Now just turn signals and tail lights.  Nothing comes on when the brake is pressed.  Checked the wiring to the brake switch and I have power, also power.
The littlest things seem to haunt me...
