Author Topic: Won't start  (Read 16302 times)
Re: Won't start
« Reply #15 on: March 30, 2014, 09:59:54 AM »
Is it normal for those ignition modules to go out?  That distributor has only been a little over three years.
Re: Won't start
« Reply #16 on: March 30, 2014, 10:14:37 AM »
If they don't have that grease between the module and the distributor where they mount, they will fail quickly.  Can't remember the name but I think it's called dielectric grease.
3WBill
Re: Won't start
« Reply #17 on: March 30, 2014, 11:18:53 AM »
 Your right Cocobolo, it is dielectric grease and is necessary to function properly
Re: Won't start
« Reply #18 on: March 30, 2014, 11:26:21 AM »
I used all that came with the replacement, should I do anything else to protect it?
Re: Won't start
« Reply #19 on: March 30, 2014, 11:46:30 AM »
Yes, They are electronic, When the work they are great when they don't you're walking. I always have a spare in the glovebox.
Re: Won't start
« Reply #20 on: March 30, 2014, 01:17:14 PM »
Actually it's "thermo grease" which is designed for very high temperatures, dielectric is to protect connections from corroding.   Dielectric will just melt away and not transfer any heat.  The thermo grease is normally a white paste.
BTW: It's normally included with a new module, it's the same stuff they use on computers to join the CPU and heat sink so the heat transfers.
« Last Edit: March 30, 2014, 01:24:28 PM by EDNY »
