Author Topic: th350c looking for wiring suggestions  (Read 8540 times)
« on: January 25, 2014, 08:49:00 AM »
Dropped my transmission off at the rebuild shop to get rebuilt, having a complete rebuild done with shift kit and some extra clutches put in and having the shift point extended to let  the engine wind up a little before shifting. This transmission has a lock up circuit  in it does anybody have any suggestions on a wiring circuit?
« Last Edit: January 25, 2014, 08:53:14 AM by 62131 »
Re: th350c looking for wiring suggestions
« Reply #1 on: January 25, 2014, 09:10:28 AM »
Found this a while back to use on my trans,,might help you  http://www.jalopyjournal.com/forum/showthread.php?t=346930
« Reply #2 on: January 25, 2014, 05:14:37 PM »
Here's a simple one.
« Reply #3 on: January 25, 2014, 09:06:18 PM »
Thanks Moose    I've got that circuit looking for something that would not require any manual setting, also  have the factory circuit was told that it would pulsate under certain loading conditions of the engine. I see B&M make a lock up kit that is adjustable and sets by the speedometer.
« Reply #4 on: January 26, 2014, 07:10:22 AM »
If you don't want to use a toggle switch you might want to go with the system that the early Chevy trucks used. They had a vacuum sensor the worked in conjunction with the pressure switch in the transmission and the brake switch to control TCC by sensing engine load. Take a look at this link and see what you think.
     Vacuum Controlled TCC TH350
« Reply #5 on: January 26, 2014, 08:05:24 AM »
Seen that circuit that is what I meant by the factory circuitry, I thought maybe somebody had come up with something else that would work better without spending a lot of cash.
« Reply #6 on: February 02, 2014, 10:50:44 AM »
another dia. for trans ....look at the last post on this page   http://gbodyforum.com/viewtopic.php?f=16&t=15369#p112530
« Reply #7 on: February 03, 2014, 05:51:47 PM »
Fatnlow
Thank you I will keep that for reference.
« Reply #8 on: May 23, 2014, 11:36:01 PM »
What did you come up with the wiring circuit...Thanks  FATNLOW
« Reply #9 on: May 25, 2014, 10:00:29 AM »
I really haven't decided which circuit I'm going to use. There is several different circuits used, you just have to choose what fits your driving habits.
