Author Topic: 1932 Coach Build  (Read 28459 times)
1932 Coach Build
« on: January 04, 2014, 06:13:21 PM »
Well I got my frame back from the sand blaster last week and was able to get my Mustang II cross member In and started boxing my frame thought I would post a few pictures. Please feel free to voice your thoughts.
« Last Edit: January 04, 2014, 07:41:34 PM by 62131 »
Re: 1932 Coach Build
« Reply #1 on: January 04, 2014, 06:32:00 PM »
Looks good....Nice clean welds. Do you have to figure out what you want for caster before you weld the FE in or is there enough adjustment in the system to be able set it where ever you need  later?
« Reply #2 on: January 04, 2014, 06:46:56 PM »
I bought my cross member from JW Garage, the caster was already built into the top hats. They came pre bent and welded, after the cross member was installed they just set on top of the cross member and centered over the front axle. It was a very simple installation. I will post some picture of the top as soon as I get the frame flipped over.
« Last Edit: January 04, 2014, 06:48:59 PM by 62131 »
« Reply #3 on: January 04, 2014, 07:16:42 PM »
Nice work, looks great!  Are you doing the welding yourself?
« Reply #4 on: January 04, 2014, 07:40:39 PM »
Yes I am, I'm getting help with the lifting and turning of the frame, I prefer to do all my own work where I can.
« Reply #5 on: January 04, 2014, 07:48:49 PM »
Cool that's the best way to keep the budget low.  Nice work :)
« Reply #6 on: January 04, 2014, 08:39:36 PM »
Thanks, I've had this project for two years collecting parts and looking for bargains to keep the build within reason.  I have a 5 year plan for this one.
« Reply #7 on: March 02, 2014, 11:35:28 AM »
Finally got my frame turned back over and finished up the boxing and welding of the front cross member, now in the process of building transmission and motor mounts. Here is the frame now.
« Reply #8 on: March 02, 2014, 11:52:33 AM »
Very nice. I just built a crossmember and boxed the front frame area on my Buick roadster. your frame is looking real good. Keep at it.
« Reply #9 on: March 02, 2014, 11:57:50 AM »
Nice work, great to see the progress.
« Reply #10 on: March 02, 2014, 02:51:22 PM »
I have the motor mounts and transmission mounts done now,  just have not taken pictures, the frame is setting outside on saw horses covered with plastic waiting on a pretty day to get it covered with rust bullet.
« Reply #11 on: March 12, 2014, 06:56:04 PM »
Thought I would add pictures of my frame after getting it painted this past weekend.  Two coats of rust bullet and a coat of a black top coat.
« Last Edit: March 12, 2014, 06:58:17 PM by 62131 »
« Reply #12 on: March 12, 2014, 07:01:33 PM »
Some more pictures with the engine and transmission installed,
« Reply #13 on: March 12, 2014, 07:20:41 PM »
Looks great! It's fun when they start to come together.
« Reply #14 on: March 12, 2014, 07:26:03 PM »
Hope to have a rolling chassis by Sunday afternoon
