33 chevy
37
38
39
40
45
Topic: 33 chevy (Read 130340 times)
Re: 33 chevy
Reply #555 on:
September 27, 2020, 06:07:34 PM »
I used the same process as Mike except after I clamped on the vise grips oldest pair I had I twisted and taped them with a hammer to remove no help available
Re: 33 chevy
Reply #556 on:
September 27, 2020, 06:45:09 PM »
Alright...liquid wrench I had not thought of that...and going back with stainless rod.....all are awesome ideas...Thank guys....
Re: 33 chevy
Reply #557 on:
September 27, 2020, 08:44:53 PM »
just thought of it, after using non pointed drift to start the process of moving the rusted rod, you can only go a short distance.
If memory serves me correctly, as i also was working alone, i clamped vice grips on end and tapped the vice grips while twisting.
Figure on vice grips coming off 3-4 times and chewing up the rod.
Re: 33 chevy
Reply #558 on:
September 29, 2020, 07:32:04 PM »
Made another buck to stabilize the hood while soaking the side
rods so I can disassemble hood...using liquid wrench to try free the rods..so far no luck in moving it so I will let it sit and periodically shoot the liquid wrench to it
Re: 33 chevy
Reply #559 on:
September 29, 2020, 07:39:06 PM »
keep soaking it. For mental comfort have friend hold it. Use body dolly on rod and whack it hard to start the loosening process. Body dolly bigger target than 3/16 rod end and allows more force to be used.
Have a friend operate the vice grips twisting.
Re: 33 chevy
Reply #560 on:
October 09, 2020, 03:51:26 PM »
Time and a lot of patience along with liquid wrench ..finally got it apart without any damage to the hood or me...
Re: 33 chevy
Reply #561 on:
October 09, 2020, 05:16:50 PM »
Awesome. Patience is tough to come by sometimes!
Re: 33 chevy
Reply #562 on:
October 09, 2020, 07:57:00 PM »
Someone suggested this after I removed the rods
Re: 33 chevy
Reply #563 on:
October 09, 2020, 08:19:52 PM »
A machinist friend of mine used to recommend this.
Re: 33 chevy
Reply #564 on:
October 09, 2020, 08:58:41 PM »
its all the same product does the same thing. Depending on which store you walk into to buy the product.
Now find some 3 / 16 stainless steel rods and never have a problem again..
If re-painting the hood, make sure you super clean it so none of the rust buster liquid remains, otherwise look for painting problems.
mike.....HAIRBALL
Re: 33 chevy
Reply #565 on:
October 09, 2020, 10:44:39 PM »
i lightly oiled mine and put them in
Last Edit: October 11, 2020, 06:33:09 AM by 62131
Re: 33 chevy
Reply #566 on:
October 10, 2020, 11:14:08 PM »
When I worked at Carquest I discovered Knocker Loose. It is definitely not the same as the rest and is the best commercial penetrating oil I have used. What I use now is a 50/50 mixture of ATF and acetone or paint thinner. The ATF doesn't need to be new. It's way cheaper than the rest.
What ever you use the main ingredient is the necessary amount of time and patients, not often a 50/50 mix.
Re: 33 chevy
Reply #567 on:
October 13, 2020, 03:06:40 PM »
Nice day to primer..
Re: 33 chevy
Reply #568 on:
October 13, 2020, 03:50:34 PM »
I liked it better red.
It looks nice and straight. These old hoods can be difficult.
RoarsRods
Re: 33 chevy
Reply #569 on:
October 13, 2020, 08:40:32 PM »
Ed doing a great job! Oh I also like the red color! Just found Stainless Steel hood hinges and other hood parts and hardware for your 33 Chevrolet! Here’s the link:
http://www.rootlieb.com/hood-hardware.html
RoarsRods
37
38
39
40
45
33 chevy
