33 chevy
20
21
22
23
45
Topic: 33 chevy (Read 130304 times)
Re: 33 chevy
Reply #300 on:
December 05, 2017, 05:29:33 PM »
Fences are completed....trying to get back on the 33....got some different bucket seats....now have to figure a way to mount them...I made a mounting template out of wood to get front up a bit...still trying to get figure what I want...
Re: 33 chevy
Reply #301 on:
December 05, 2017, 05:55:34 PM »
Nice look seats..what are they out of?
Re: 33 chevy
Reply #302 on:
December 05, 2017, 05:59:40 PM »
Ed...they are from a 2006 Hyundai Tribron...2 door Sedan gave $20.00 for them
Re: 33 chevy
Reply #303 on:
December 05, 2017, 07:03:20 PM »
I played around with shims and 2X4s until I felt comfortable with the position and angle. It's worth the time though as I'm real happy with the comfort of mine on a long ride. Make sure the adjustments a right so both you and the wife are comfortable.
Re: 33 chevy
Reply #304 on:
December 05, 2017, 07:20:05 PM »
I used 2" X 1/8" flat band steel and formed two legs for each seat that bolted to the floor and are welded to the seat tracks.
Re: 33 chevy
Reply #305 on:
December 05, 2017, 10:43:58 PM »
Ed glad the honey do's are done and your back on the 33. Those seats look comfy
Like Tom said, well worth the time to set up for a good comfortable fit now, your back will like it later!
Re: 33 chevy
Reply #306 on:
December 22, 2017, 07:51:14 PM »
Seat risers with under floor stiffing/mounting plates ...needs finishing and painting
Last Edit: December 22, 2017, 07:53:57 PM by FATnLOW
Re: 33 chevy
Reply #307 on:
December 24, 2017, 08:47:15 PM »
Nice fab work Ed! That should do it.
Re: 33 chevy
Reply #308 on:
December 25, 2017, 08:35:49 AM »
Nice fit Ed. Great job!
Re: 33 chevy
Reply #309 on:
December 30, 2017, 09:04:49 PM »
Getting seats installed driver seat fits and feels really good.... colder than heck here garage heater but the dust....
Last Edit: January 12, 2018, 05:55:23 PM by FATnLOW
Re: 33 chevy
Reply #310 on:
December 30, 2017, 10:11:31 PM »
Brackets turned out nice Ed, seats looks comfortable. What, no console?
Haha I almost forgot how mine had room
Re: 33 chevy
Reply #311 on:
December 30, 2017, 11:26:06 PM »
No room for console i fabed..due to the 700R4 trans....need to plan another one?
But seat is comfy and sit right...best part easy to remove
Re: 33 chevy
Reply #312 on:
February 02, 2018, 05:46:48 PM »
Trying to get things done ....installed radiator so I can put in top and bottom radiator hoses and figure out what I'm going to use in transmission lines. Thought about using the Teflon stuff with the braided wire outer covering
Re: 33 chevy
Reply #313 on:
February 02, 2018, 05:56:21 PM »
Looking good Ed! Looks like your making progress anyway.
Hows your weather? We've been getting the warm/cold/warm thing here, 52 right now.
Last Edit: February 02, 2018, 06:03:01 PM by sammons
Re: 33 chevy
Reply #314 on:
February 02, 2018, 06:49:57 PM »
for the tranny lines your going to want to run -6AN hose and hose ends........3/8" Just the rubber lined should be good braided stainless or the new black fabric covered hose. Talk to GODWIN ? to get right type. Teflon is for brakes.
You may want to consider running an inline cooler , the finned tube shape type in aluminum mounted to the side rails. Cuts down on the heat going into the radiator.
With that air con in front of radiator make sure you have a fan that can really pull air thru. Fan has to work 2 times as hard to draw thru 2 units.
20
21
22
23
45
33 chevy
