Author Topic: 1932 Pontiac Six build  (Read 161268 times)
« Reply #495 on: December 15, 2019, 10:45:00 PM »
I tried setting it there. Not enough room and the shocks would bottom out too soon .
At this position the axle will hit the bumpstops before the diff.
The pic doesn't show that it's just forward of the axle. I only have to move the brake line T an inch.
There's 6 inches of uptravel. 😱
« Reply #496 on: December 16, 2019, 07:06:23 AM »
Sounds good.  Stitch it in!
« Reply #497 on: January 19, 2020, 12:20:16 PM »
Looking into something else , I found some shock mounting info. Off-roaders and drag guy's will mount the shocks in front of the axle to prevent the pinion from going up and preventing axle wrap.
That's all I needed. Guess I'll finish welding it in.😊
« Reply #498 on: January 20, 2020, 08:49:45 AM »
Post some pic's of what you are doing, if you can.
« Reply #499 on: January 26, 2020, 11:12:50 PM »
Hopefully tomorrow some pics.
I have the mounts all burned in.
My neck hurts from laying on my back,  holding my head up , helmet on and stick welding. 😛
« Reply #500 on: January 26, 2020, 11:27:28 PM »
sounds like you also need a hoist !!!!!!!!!!!!!!!!!!
« Reply #501 on: January 27, 2020, 08:39:41 PM »
Yes.
Even a pit would be nice.  ;D
« Reply #502 on: January 28, 2020, 09:53:10 PM »
Shocks are done. 😁
I know , it took long enough. 😉
I still need to cut tailpipe to move it more forward to get it away from the shock.
« Reply #503 on: January 29, 2020, 05:27:34 PM »
Looks great Rattiac!
« Reply #504 on: January 29, 2020, 07:03:25 PM »
Looks real good Rattiac…..what's the rush?
« Reply #505 on: May 07, 2020, 02:01:06 PM »
New parts for the 32.
Better deal locally than ordering through summit.😯
« Reply #506 on: May 07, 2020, 02:28:15 PM »
OH YA THATS FUN BIG TIME.   Now wheres the phone number for the hoist??  Sooner or later your going to have to bit the bullet and get one.  My ceiling at 8 ft is too low for one.
« Reply #507 on: May 08, 2020, 07:44:06 PM »
Mine is also 8ft .
I've seen people put em outside in front of the garage door.
That's all my neighbors need to see my rusty junk in the air. 😱😄😁
« Reply #508 on: May 09, 2020, 12:24:09 PM »
Guess I'm lucky. If the neighbors can see my rusty junk they have been trespassing for a couple of miles.  :)
Coming home in the snow sometimes it doesn't feel like luck.  ;D
« Reply #509 on: May 09, 2020, 01:38:17 PM »
Hopefully in the next few weeks I'll be getting this car back on the road. It's been sitting since October. 😢
Gonna leave a list here for stuff to check off.
1.) Install new fuel line at carb. (Check)
2.) Remove tailpipe and chop off 3" after muffler. (Check)
3.) Fix leaks near thermostat and trans cooler.
4.) Remove old ride control shock on left rear.(Check)
5.) Go for a drive and do a big long Smokey burnout. 😈
« Last Edit: May 31, 2020, 10:30:53 PM by Rattiac »
