Author Topic: Recognize this carrier ? Richmond?  (Read 7150 times)
« on: June 11, 2013, 07:58:21 AM »
Parting out a 95 Z28 LT1 and just opened the rear axle cover. It has Richmond 4:10 gears but not sure which posi carrier it is..anyone recognize it?
Re: Recognize this carrier ? Richmond?
« Reply #1 on: June 11, 2013, 08:58:50 AM »
Looks like it has a reluctor ring which would seem to indicate it was from a vehicle that had stabilitrack. I know GM SUV's had the setup in most models starting in 2007 but I don't know the full history of the system
« Reply #2 on: June 11, 2013, 10:52:41 AM »
The rear end was re-done, I have the original ring/pinion in a foam box, the Z28 RPO code is G80 which I thought was the standard "gov-lock" (AKA GOV-BOMB)...which this one isn't.  I'm kinda thinking they put in a Richmond posi kit..which would require installing the reluctor. The full kit comes with posi carrier, ring, pinion, shims, bearings, seals.  Those full kits go for around $500-$600
Want to sell it...but need to ID it first.  May make a post on the HAMB.
« Reply #3 on: June 11, 2013, 08:25:24 PM »
Go to the site below and arrow through "all" of the images and see what you think
Z28 rear
« Reply #4 on: June 11, 2013, 10:52:16 PM »
One of the guys on the HAMB id'd it as an Auburn posi because of the cone shape.  Just wanted to know what I was trying to sell!
If it was an 8.5...would keep it for myself.
