About one third of the WW II diesel submarines were outfitted with Fairbanks-Morse 9 cylinder (and later 10 cylinder) opposed piston engines. They were running fools. Served on one with Fairbanks and 3 with Jimmies. The Fairbanks would outrun, outlast and require far less attention. Biggest fear was water seeping into the cylinders and causing a hydraulic lock that would bust the vertical shaft that connected the two crankshafts. Sadly Fairbanks Morse went out of business. Side note: the locomotives of today have the same propulsion system (diesel/electric) and same engines as the old subs.
