Author Topic: Source for these flexible fuel lines  (Read 2449 times)
« on: May 05, 2021, 03:12:14 PM »
These fuel lines in the picture are from a Corvette.....trying to locate a source that sells these type of flexible fuel lines with open ends so I can flare them with my own flare nuts.  Looking for 3/8" but 5/16" (for return lines) would be great.
Any ideas?
Re: Source for these flexible fuel lines
« Reply #1 on: May 06, 2021, 06:34:40 PM »
Don't know of anyone who sells "universal" lines like this. Is it possible to buy Corvette lines, cut off the fittings and use your own?
« Reply #2 on: May 06, 2021, 08:09:46 PM »
I need to run a salvage yard and just remove some used lines from the old junkers.
Those Corvette lines run a couple hundred dollars.
« Reply #3 on: May 06, 2021, 11:18:16 PM »
I spent almost an hour in O'Reilly yesterday figuring a way to make the tranny cooler lines in my '92 Suburban connect. It go easy one I talked them into letting me look at the ones behind the counter. It was so much easier when I worked there.  :) I don't know what my friend did to this before I got it or why they weren't connected.
