General Discussion - Intros
My first truck
3
4
5
6
8
Topic: My first truck (Read 19040 times)
Re: My first truck
Reply #45 on:
April 28, 2021, 08:06:03 PM »
Guess I celebrated too soon. The po455 code came on yesterday morning and this morning also 🤨.
States a large evap leak. Been looking at videos, I have a few things to check out including a purge valve that people install upside-down.
Gonna let it go for a bit and switch to the fuel pump on the jeep.
Re: My first truck
Reply #46 on:
April 28, 2021, 08:50:59 PM »
Well it's a large evap leak...should be easy to isolate with a smoker. There are a lot of videos showing how to make a smoker also. Up here the filler neck gets rotted and leaks....fuel caps are the first/easiest item to check. Look for rust around the filler neck where the cap rubber contacts it. You mentioned a new fuel pump...if it was for this vehicle and it is an internal tank pump...did you get a good seal?
Sorry..just re-read your post...getting your vehicles mixed up.
Last Edit: April 28, 2021, 08:52:47 PM by EDNY
Re: My first truck
Reply #47 on:
April 29, 2021, 02:19:16 PM »
Sorry, I'll keep my pickup somewhere else.
Re: My first truck
Reply #48 on:
April 29, 2021, 02:30:51 PM »
Sixball::;
Feel free to post your truck stuff here, I dont mind.
Would like to see pics of it.
The newer stuff isn't too bad to work on, I picked up a cheap scanner for mine. Helps point ya in the right direction.
Re: My first truck
Reply #49 on:
April 29, 2021, 09:12:44 PM »
Quote from: sixball on April 29, 2021, 02:19:16 PM
My fault ...keep listing your situations...we want to help!
Re: My first truck
Reply #50 on:
April 30, 2021, 01:03:29 PM »
Ok, I know I tend to ramble and steer things away from the original topic.
I hope to finish the winch wiring today and maybe get some pictures.
Re: My first truck
Reply #51 on:
April 30, 2021, 05:33:13 PM »
sixball---Keep it up I enjoy your posts!
Re: My first truck
Reply #52 on:
April 30, 2021, 09:05:55 PM »
Thanks Ed, I really enjoy this site and the good people here.
I finished the winch connections from the battery to the master switch done and the electric cables run to the rear of the truck. No time tomorrow there's grandsons' baseball to watch. Sunday I'll run the front cables. I'm still waiting on the front hitch to ship. It's been on backorder for several weeks. Some pictures soon.
Re: My first truck
Reply #53 on:
May 02, 2021, 08:17:45 PM »
I finished the wiring for the winch today and tried it out by moving a '90 S Suburban a few feet further than my tractor would a few years ago. I spooled out all but the east wrap on the spool and winched the pickup back the the Suburban to tighten the cable and see how neatly it spooled. It did well. Not the fastest but it didn't hesitate. It is heavy and I can see than moving it from front to rear or installing it in a spot so steep that I would need it might be a problem. I have a synthetic rope and an aluminum fairlead that will save twenty + pounds which will help.
The power leads tuck away out of site and the remote works great. This will help with some projects around the place like the Ford Tractor that has been stuck on the hill for a couple of years. A few pics, sorry for the fuzzy ones.
Re: My first truck
Reply #54 on:
May 03, 2021, 12:58:29 AM »
Nice setup ya got there. 👍
I like the disconnect. Not many people do that anymore.
Last Edit: May 03, 2021, 01:02:40 AM by Rattiac
Re: My first truck
Reply #55 on:
May 03, 2021, 09:00:13 AM »
Looks like a nice, clean setup. And, you know you'll make good use of it.
Re: My first truck
Reply #56 on:
May 03, 2021, 12:54:04 PM »
Thanks! It will get used. Hopefully the front hitch will ship soon.
I like the disconnect as I don't want the potential of a #2 cable dead short that I can not turn of. The connection the the side post battery took some thought to get studs the correct length and good connections for all wiring. The red + cable with the 150 amp circuit breaker provided a huge hot area where a dropped wrench could have put on quite a show so I wrapped it with the piece of rubber tool drawer liner. I still need a shield on the disconnect. A friend of mine built a neat little DC welder that ran off his truck battery to make emergency repairs away from the shop. There is power there. Our home power is solar. I once dropped a 9/16 wrench across two banks of big 24V batteries. I had to replace it once I could see again.
Lucky it was Craftsman.
When I recover the Ford Tractor I'll make a video.
Re: My first truck
Reply #57 on:
May 03, 2021, 06:51:35 PM »
Like your set up, nice neat, build your shield and you will be ready
Re: My first truck
Reply #58 on:
May 03, 2021, 07:18:59 PM »
Thanks, the last picture is the 20' of #2 cable, welding lead, that goes to the back. When I bought that kit there was an 18" option. I'm glad I didn't get it. The pickup is a 1500 extended cab (small doors) short bed. There isn't much of the 20' left over. The front harness is 8' and there is a couple of feet extra. I think I am going to build a set with the Anderson style connector on one end and jumpers on the other. There isn't much room to get to the battery and I could get or give a jump through the winch cables.
This all started because my son and I borrowed a car hauler with a winch. I wanted a winch for my trailer, and I still do. I'm building a mount on the trailer for this but I don't think I'd ever need a 12,000 lb heavy ass winch there. So.........
Re: My first truck
Reply #59 on:
May 04, 2021, 08:52:07 PM »
Rattiac, Anything on the leak or the Jeep fuel pump?
3
4
5
6
8
My first truck
