General Discussion - Intros
My first truck
7
8
Topic: My first truck (Read 17822 times)
Re: My first truck
Reply #105 on:
August 24, 2021, 12:31:11 AM »
After recieving an alignment.
I hooked up the trailer for a camping trip. Shortly into the trip, the upper radiator hose blew when it kicked down a gear during a hillclimb. Good thing for AAA.
Had it towed back home and switched to Plan B.
Swapped gear to the jeep, my dad offered to haul the trailer up the mountain with his RV. I followed and towed it back home.
It has the radiator cap in middle of the hose, made of plastic. I wonder if they have a steel version of this ?
Last Edit: August 24, 2021, 12:40:57 AM by Rattiac
Re: My first truck
Reply #106 on:
August 24, 2021, 01:54:37 PM »
I don't know but you could probably check on line by brand and retailer. The plastic hose is probably as good as a plastic radiator and it won't rust.
Re: My first truck
Reply #107 on:
August 25, 2021, 02:02:54 PM »
I think ill get the OE upper hose unit and grab a aftermarket coolant inlet just in case. Leave it it the truck for a quick roadside repair.
While im at it, do the lower as well.
Pretty sure im going back to the saltflats for World of Speed and take the truck for more testing.
Last Edit: August 25, 2021, 02:11:27 PM by Rattiac
Re: My first truck
Reply #108 on:
August 28, 2021, 05:02:46 PM »
Dusty is back up and running. New hoses installed.
Had to get a remote hose clamp removal tool to get the lower hose off the radiator as delicately as possible. Worth the $35.
To bleed these 4.7's is a bit different, theres a bleeder screw/allen bolt on the top of the engine where the hose connects. The thermostat is on the bottom of the engine 😮. Didnt change that yet but gave the long bolts a PB soaking .
Had to remove the battery to install the upper hose and the battery box was a mess, terminals too. All that was cleaned.
Went to the car wash. Cleaned the engine and all the coolant off the body.
Re: My first truck
Reply #109 on:
August 29, 2021, 12:38:44 AM »
I have become a big fan of dielectric grease on battery terminals.
Re: My first truck
Reply #110 on:
August 30, 2021, 12:21:48 AM »
Im a stickler when it come to dirty battery post's on my vehicles
I have a red spray (not sure what its called) that I put on em.
Took the truck/trailer up over the mountain today and wandered around Cabellas. Grabbed some garlic fish bait.
Passed the test. Ready for the saltflats.
Last Edit: August 30, 2021, 12:23:32 AM by Rattiac
Re: My first truck
Reply #111 on:
August 30, 2021, 11:10:41 PM »
Where can you catch garlic fish? That sounds good.
Re: My first truck
Reply #112 on:
January 17, 2022, 12:53:35 AM »
Grabbed some 4 inch amber LED fog lights. Drilled out the holes below the bumper and mounted em with a L-bracket.
Wired it all up today. Super bright. Pointed em down below the headlights pattern on a wall.
Can't wait for a snow storm.
Re: My first truck
Reply #113 on:
January 17, 2022, 12:38:24 PM »
I've been thinking of the same thing for my pickup. Let us know how it works. Thinking snow more than fog here but when we have it it is thick.
7
8
My first truck
