Author Topic: LS in my S10 Chassis  (Read 4237 times)
« on: June 27, 2020, 05:53:56 PM »
Well I got the 5.3 mounted in the S10 chassis for my 1953 3100 project and ordered the recommended Hedman headers and they would work if the engine set higher.  You can see the first tube hits the control arm.  Is it possible to raise the engine?  Any suggestions?
Re: LS in my S10 Chassis
« Reply #1 on: June 28, 2020, 03:40:59 AM »
if that is the recommended header for the LS motor in a S10, then looks like seller getting headers back.  They are supposed to fit the design combination they are made for.  If motor needs to be higher and so would trans mount.  Better contact seller and get straightened around.
You want to deal with JEGS or SUMMIT, I would think.
« Reply #2 on: June 28, 2020, 11:33:46 AM »
Thanks. The headers were recommended by Code 504 and purchased from Jegs.
« Reply #3 on: June 28, 2020, 02:02:17 PM »
I would like to know if anyone has experienced this and resolved it. Thanks
