Author Topic: Insulating floors from the bottom?  (Read 3005 times)
« on: March 15, 2020, 02:03:11 PM »
I don't want carpeting in my 33 coupe and would like to insulate the aluminum diamond plate floors from the bottom. There is plenty of frame work under the floor for cross support etc, but looking for insulating techniques/suggestions from the bottom.
Probably will be using "cleared" diamond plate for the door cards also, that way I can bolt the Saturn window cranks right to the door cards for a solid support.
Re: Insulating floors from the bottom?
« Reply #1 on: March 15, 2020, 02:35:01 PM »
Ed, i've used a product called Total Coat (Chemicar co.) since about 2005. At the time they had several types, regular undercoat,  sound control, etc. On my coupe i used "premium sound control" a waterbase plastic type polimer, so clean up was easy. Works really well on taking that tinny sound out to a dull thud when tapped.
I'm sure many products are similar or same, Lizardskin comes to mind.
Sorry for upside down pic of bottle and spray head. Stupid phone won't allow flip😡
« Reply #2 on: March 15, 2020, 06:45:58 PM »
sammons..thanks for that info..plus it's something you used.
BTW: Can you take pictures with your phone upside down :o
« Reply #3 on: March 15, 2020, 07:44:55 PM »
Ed, its got a mind of its own. Cheap POS, pic was taken right side up. Preveiw, right side up, gallery upside down🤯  It did the same thing couple days ago, some days auto rotate screen works, next it don't.
I already put the stuff back up when i discovered it had flipped after it hit gallery😡    Sorry man!
« Reply #4 on: March 15, 2020, 11:23:26 PM »
I think there is a "command" that you can hit on these computer key boards that flips the screen (seriously).
 Maybe you just stand on your head to fool the phone ;D ;D (not seriously)
« Reply #5 on: March 17, 2020, 09:20:25 AM »
Although I have never used it, I hear good reviews on a product called Lizard Skin. Might be worth looking in to.
« Reply #6 on: March 17, 2020, 02:07:20 PM »
Was thinking about laying down a sheet of that silver insulation material. Have enough floor framing to support a thin layer of silver insulation sheeting?  Maybe could also use something like Lizard Skin as an adhesive and insulator?
« Reply #7 on: March 17, 2020, 03:29:00 PM »
I don't really know how well lizzard skin would work as to adhear the insultaion up. It would stick well to aluminum and foil also. The bond? Try some and see i guess.
« Reply #8 on: March 17, 2020, 04:25:31 PM »
There is plenty of rectangular tubing under the floor from one side to the other, so if I laid insulation sheets down then the floor on top - shouldn't have a problem with it falling down.  This stuff from Lowes feels like a plastic bubble wrap...not sure about how it would do with heat from the exhaust system?  Muffler is about 8" from floor, pipes about 10"
« Reply #9 on: March 17, 2020, 05:14:38 PM »
Insulation from the bottom I believe I would use the lizard skin, i think its a sound deaden er and undercoat system in one
« Reply #10 on: March 18, 2020, 10:46:09 AM »
I, personally would be hesitant to use that underneath. Heat may be a factor as well as potential rips and moisture between the floor and foil. Just my two cents.
RoarsRods
« Reply #11 on: April 11, 2020, 09:56:56 AM »
I Agree with Chopper! Ed here is my all new metal 34 Roadster floors and I used a couple different insulations! KnoKnoise sound deadening material and this fire rated sound deadening material! Here is the link: https://www.summitracing.com/parts/THE-14125
Here are a few pics of my new floors with 1 inch square tubing structure to support the floor loading!
RoarsRods
« Last Edit: April 11, 2020, 09:59:44 AM by RoarsRods »
« Reply #12 on: April 11, 2020, 05:59:48 PM »
That's some real nice looking work!
« Reply #13 on: April 11, 2020, 08:49:44 PM »
RoarsRods
Thanks for the response...my plan is to have aluminum diamond plate floors inside the car...in other words I want aluminum floors...no carpeting.  Any insulation needs to be under the aluminum floors.
