Author Topic: Magline Trailevator (trailer) anyone have experience with them?  (Read 3293 times)
Recently picked up an older Magline hydraulic trailer....would be great for loading lathes, safes, tools etc. It has a fiberglass 100 gallon tank, pump and 100' fire hose setup that I'm removing. (Dexter wheels and surge brake)
Attached a picture of mine which has the "manual hydraulic pump" on front along with a video of a later unit with electric hydraulic.
Anyone have any experience with one?
https://www.youtube.com/watch?v=nwQNWUyQtQA
Re: Magline Trailevator (trailer) anyone have experience with them?
« Reply #1 on: June 20, 2019, 12:34:01 PM »
That will be handy! I could have used that many times. Moving my mill and lathe would have been much easier and safer.
« Reply #2 on: April 05, 2021, 12:58:45 PM »
OLD POST ....I did get the trailer painted, new tires etc a while back.  The front hydraulic pump rubber boot is cracked and some water got into the pump tank.  Been trying to source out another pump or better yet a rebuild kit.  The pump activates the two single action cylinders.
Anyone have experience locating hydraulic pump rebuild kits?  Thought it might be similar to a master cylinder but I can't locate any sources for the pump (id tag picture attached).  There are two casting numbers on the pump body 1014 and B1120.
« Reply #3 on: April 05, 2021, 07:36:21 PM »
Ya could upgrade to a more modern pump like on those newer black dump trailers you see everywhere,  if you can't find parts.
« Reply #4 on: April 06, 2021, 07:18:38 PM »
Haven't had a chance  to really work on it yet...there are no rubber diaphragms inside like a master cylinder (has small pistons).....looks real nice inside...acts like it needs to be primed.  Hydraulic fluid might need a few more degrees...going to warm up around here in the next couple of days.
« Reply #5 on: April 06, 2021, 07:33:07 PM »
The hydraulic pump on my Ford tractor looses it's prime if it sets for a while. Bleeding it while cranking the engine gets the air out and it works fine. Some day I hunt that leak.  :)
