Author Topic: Power steering  (Read 17516 times)
Power steering
« on: March 14, 2019, 10:52:05 PM »
Ok here goes.....been told by other gear heads that Thunderbird power rack is compatible with the Delco power steering pump...in that you don't have to reduce pressure and flow rate...1987??? Rack....anyone confirm this before I buy the units??
Re: Power steering
« Reply #1 on: March 25, 2019, 05:46:26 PM »
All I know the thunderbird is a step up in quality from the mustang. and it's using a gm style pump with no problems yet.
Re: Power steering
« Reply #2 on: March 25, 2019, 06:44:54 PM »
In doing more research Thunderbird rack are mounted front steer....I have rear steer so will be researching Omni power rack.....search goes on . emailed Heidts on what they suggest but no answer from them...
Re: Power steering
« Reply #3 on: March 25, 2019, 07:06:03 PM »
My front end is a TCI and came with an Omni rack.  Mine is a manual rack though.
Re: Power steering
« Reply #4 on: March 25, 2019, 07:36:03 PM »
use the Omni rack same as KUGEL recommends and so does TCI, you do not need power steering, you know that, why fight whats right.  My 35 chevy coupe, roadster both use KUGEL with Omni, both weigh around 2600 pounds, so what tank are you using that needs power ?????????
You driving yourself nuts for nothing that's needed. So in the words of somebody " knock yourself out ".
Re: Power steering
« Reply #5 on: August 05, 2019, 08:06:05 PM »
Just found this and would like to pass on my experience.   On the '39 I put a 1989 T'Bird NON-SPORT power rack.  It drives very nice without twitching.  Would recommend it to anyone with a MII front end.  Lots cheaper too!  For all the problems that people have reported about the miss-match with a GM pump and Ford rack I would think someone would have come up with a bracket to mount a Ford power steering pump to a GM motor. Seems like a simple solution.
Re: Power steering
« Reply #6 on: August 06, 2019, 08:46:53 PM »
39 deluxe...is your MII rack front steer or rear steer??wanting to go with power steering and I have the rack behind the cross member???...as I understand these T bird racks work well in front steer racks...
Re: Power steering
« Reply #7 on: June 25, 2020, 04:30:21 PM »
Sadly the T'bird rack is a front steer.
