Author Topic: Front fender brace  (Read 6468 times)
Front fender brace
« on: January 21, 2019, 03:35:08 PM »
Does anyone know if there is a difference in a 1930 and a 1930 front fender brace?  If so, what makes up the difference?
As always, thanks all...
Re: Front fender brace
« Reply #1 on: January 22, 2019, 03:24:01 PM »
No, a 1930 front fender brace and a 1930 front fender brace are identical................I'm sorry Munch, I couldn't resist.  ::)
I'm not sure if this helps. https://www.ebay.com/itm/Chevrolet-Chevy-All-Models-Front-Fender-Well-Bracket-Brace-Pair-1930-1932/351348525916?hash=item51ce010b5c:g:QPkAAOSwBahVDX9e
I found that rear fender braces and running board braces are interchangeable from 1930 to 1932, no luck on front braces.
« Last Edit: January 22, 2019, 03:36:00 PM by chopper526 »
« Reply #2 on: January 22, 2019, 05:08:04 PM »
Thanks Chopper, I meant 1930 and 1931.  Sometimes I'm a few pickles short of a barrel.
 ;D
« Reply #3 on: January 22, 2019, 06:10:24 PM »
I have a pair of these for my 32, I wasn't sure where they went exactly please explain the purpose
« Reply #4 on: January 22, 2019, 06:21:30 PM »
question, are we trying to figure out if your looking for :  FENDER ** WELL ** BRACES or front fender braces that sit under the head light mounts.   ?????
« Reply #5 on: January 22, 2019, 06:47:13 PM »
the picture Chopper posted was well brackets correct?
« Reply #6 on: January 22, 2019, 10:56:07 PM »
yes, they mount too the frame and go over to the fender well and bolts are run thru.  If running a factory original frame the holes should be there.  I had a pair of those 30--32 but much to narrow for 34-35 standard frame.
 Got lucky on ebay in November and got the correct 34-35 dual sidemount parts with locks.
« Reply #7 on: January 23, 2019, 12:02:35 PM »
I am referring to the brace that sits under  the front fender and the headlight bar bolts through from the top. Similar to the picture of the Ford brace, but with a triangular plate on top with three holes for the headlight bar mounting.
« Reply #8 on: January 23, 2019, 02:38:12 PM »
according to the parts book, 1929-1930 fender braces are the same.   1931-1932 use a different brace.  Like the Fender braces you have pictured.
« Reply #9 on: January 23, 2019, 05:17:14 PM »
Thanks Mike...
« Reply #10 on: January 24, 2019, 12:25:35 PM »
Now I just have to find them.  I got one for the passenger side that is in pretty good shape, but I need on for the driver's side.
62131 do you not run with them on your car?
« Reply #11 on: January 24, 2019, 02:46:45 PM »
Munch, if you're not already aware of it, try:  searchtempest.com You can search, virtually craigslist nation-wide with just a few clicks.
« Reply #12 on: January 24, 2019, 04:03:16 PM »
I was not, thanks Chopper...
« Reply #13 on: January 24, 2019, 05:21:16 PM »
You are talking about the ones chopper posted a picture of? Not at this time, I knew they went under the front fenders and I assumed they were only used on cars with the spare tire wells in the fenders to support the weight of the spare. I replaced my fenders with fiberglass ones. If they need to be there to support the fenders I guess ill have to figure out how they mount.
« Reply #14 on: January 24, 2019, 10:59:57 PM »
I don't have them on my 34 coupe...it has thick fiberglass fenders.  The fiberglass fenders on my 33 coupe are thin...so I'm going to laminate some braces into the fenders.
