Author Topic: Heater talk. Brrrrrrr  (Read 5564 times)
Re: Heater talk. Brrrrrrr
« Reply #15 on: December 30, 2018, 08:29:33 PM »
Had it mounted today and already gonna move it up 1.5" .
The heater in the shop wont stay lit so not much progress.
« Last Edit: December 30, 2018, 08:31:07 PM by Rattiac »
« Reply #16 on: December 30, 2018, 09:49:45 PM »
I ordered this EBay unit. Found one that didn't use weak computer fans.
Also van floor heaters is another alternative. (3rd pic). Advantage is bolting up to the firewall flat.
I need to find an ash tray for my 32 dashboard now. Anybody know where I can find one ?
I have one if your interested,  it needs a little work the lid is sprung
quote]
Rattiac  sorry for the delay got busy with house things (honey do's)  and forgot  will get them tomorrow
« Reply #17 on: January 01, 2019, 01:17:54 PM »
Sounds good.  8)
Gonna try to fix the (propane) heater today, so I can finish the heater install. If that makes any sense. 😁
30° in the shop. 😬
Im hoping the thermocouple needs cleaned.
Grabbed another thermocouple at Lowe's but this looks like a whole different animal.
« Reply #18 on: January 01, 2019, 06:41:13 PM »
Alrighty then. Propane Heater is going and staying at 55°.
Install is almost complete. Except for wiring.
I need help !!!
I dont get thier wiring instructions.
3 wires from switch (red, blue, black)
2 wires on heater/motor box.
Now shouldn't it be like this at switch.
Red - power in
Blue- power out to motor (+)
Black ground
Thier instructions make no sense.
« Last Edit: January 04, 2019, 01:37:56 PM by Rattiac »
« Reply #19 on: January 01, 2019, 10:11:42 PM »
Rattiac I looked up that Meco unit you have, no wire diagram to be found. That is a strangely worded instruction sheet.
They way I read it (crosseyed) is:
1-Red wire from switch and the red wire from the motor go to 12v positive switched battery.
2- Black wire from switch goes to chassis ground.
3- Blue wire from switch goes to motor Black as a motor ground.
Probably using that blue wire as the variable ground for fan speed?
Maybe someone else will have some input on this. Just the way I read it, might not be correct!
Add* I thought more about that, I don't understand why they have 12v power to switch if they are using ground as the on/off/speed control. Unless the switch has a light inside? You may have to get a muti-meter out and just hook up switch to see if the Blue wire is sending a resisted ground or power out.
« Last Edit: January 02, 2019, 10:26:34 AM by sammons »
« Reply #20 on: January 02, 2019, 11:41:21 PM »
Hooked up the multi meter and the ground resistance went up as I turned the dial.  :o
Houston, we have a heater.  ;D
Well, learned something new in electrical .
Tomorrow I'll fire it up, bleed the system and give it the official test.
« Reply #21 on: January 03, 2019, 10:15:47 PM »
Testing complete. Once it gets up to 180° it puts out some really good heat but..... apparently I have a 160 thermostat I forgot about.
When I turn the heater on , I can watch the temp go back down to 160.  :o.
Probably time to change that thermostat here soon. ;D
« Reply #22 on: January 04, 2019, 01:35:11 PM »
Ready whenever you are. Last night I was able to drill a few 1/8" holes in the wood to see check clearance underneath. Looks like it's gonna work.
 8)
« Reply #23 on: January 04, 2019, 06:57:41 PM »
Sorry Rattiac, I've had cell phone issues (A Rotten APPLE) had to make two 250 mile round trips to the nearest Apple store to get my 6 month old phone replaced under warranty. I'll send you the pictures first thing in the morning  If you want to send me your personal email or cell number I can send it either way you prefer
« Last Edit: January 04, 2019, 07:02:46 PM by 62131 »
« Reply #24 on: January 04, 2019, 08:18:54 PM »
Text is probably easier. PM sent. 8)
« Reply #25 on: January 15, 2019, 06:21:23 AM »
Rattiac     just wondering if you received your package I sent you?
« Reply #26 on: January 15, 2019, 09:18:51 AM »
Tracking says it should show up today.
« Reply #27 on: March 31, 2019, 09:56:03 PM »
Starting to wonder. Did I mount the heater too high ? Or something else ???
Temp sweeps up to 220° ish and then drops back to 180 fairly quickly. No boiling.
« Reply #28 on: March 31, 2019, 10:29:40 PM »
Could be where your sender for your guage is located gets hotter before  the thermostat does. cool water from the radiator sitting on the top of the thermostat.
« Reply #29 on: March 31, 2019, 10:59:36 PM »
Reminds me of my S10 (2.2 engine) temp would shoot up high then just drop.  Figured the thermostat was working properly but installed a new one anyway.  Still goes up and drops when the thermostat opens.
Some of the old timers around here still drill a small hole in the thermostat plate so it can bleed itself.
