Author Topic: What are your winter plans for your car??  (Read 18769 times)
Re: What are your winter plans for your car??
« Reply #15 on: November 08, 2018, 07:45:44 PM »
It's hard to finish one project when you mind is on another. I can't remember where you were on the Dodge, but if it's a roller they sure sell easier. If you can get it sold and come out alright on time and money, go for it. Your '55 is probably much closer to driving, and in all honesty you would probably get more enjoyment out of it.
There are a lot of deep projects out there on the cheap. People like us don't mind diving into where most will shy away from. Too bad you can't keep them all,  but money and storage is usually short.
My buddy still has his '24 Dodge coupe and an extra coupe body I give him. He is years away from doing anything with them. Just thinking if you wanted a big project Dodge later, probably be real reasonable  ;D
« Reply #16 on: November 08, 2018, 10:58:23 PM »
plans for the winter , car related.  Today assembled the 4 wheel dollys so I can move my coupe up next to the side wall.  Then take the phaeton ad move it right next to it using same dollys.  Hopefully this will give me enough room to get my 2014 Chrysler 300 in beside the both of them for winter storage unit.
Gotta figure out how to get out of the 300, get wife inside have her climb over seat onto rear seat and exist thru fold down rear seat and trunk ............LMAO.  No way am flexible enough to do that.
For rest of winter continue onwards with 35 chev roadster chassis build, getting SOME stuff done every day.
« Reply #17 on: November 09, 2018, 08:49:53 AM »
The plan is to install FITech fuel injection.  That will mean running new fuel line and return line.  I also want to get the outside door handles hooked up and working the bear claw latches.  Maybe if time allows start to fit the top on the car.
TFoch,
 I installed a FITech fuel injection on the 30 and am very pleased.  Your going to love it...
Munch,
Did you use the external pump or the pump located in your fuel tank?  If you used the external one I was wondering how loud it was.
Tom,
I used the Aeromotive Phantom in-tank solution, great unit nd not loud at all.
Good luck, Munch
