Author Topic: Power steering  (Read 5429 times)
Power steering
« on: October 11, 2018, 08:37:50 AM »
Any one running power rack and pinion???  if so what is your setup?
Re: Power steering
« Reply #1 on: October 11, 2018, 12:57:10 PM »
Mine is not power steering.  The set up I have is a TCI front end with a rack behind the crossmember, a Dodge Omni one I believe.
Re: Power steering
« Reply #2 on: October 11, 2018, 01:07:15 PM »
Like Tom I'm using a Dodge Omni rack behind the front member  but mine is a power rack with a Delco pump. The front suspension is Kugel.
Too soon we get old too late we get smart. One out of two aint bad 8)
Re: Power steering
« Reply #3 on: October 11, 2018, 01:30:38 PM »
my 35 coupe has a kugel with Omni rack, NO power assist.  Not needed even with 60 series tires.
My 35 phaeton has a cricket rack about 5 turns lock to lock on JAG XKE ifs, way to slow.  Have another OMNI rack going to swap in place.
Unless you have a really heavy car the Omni rack is sufficient.
Re: Power steering
« Reply #4 on: October 11, 2018, 06:26:15 PM »
Searching for all parts to convert to power rack...wanting to get the smallest power steering pump,found one that you can order 1200 psi or 850 psi....had a question on required or acceptable pressure on the Omni power rack...would the 850 psi pump be compatible with the Omni rack...rather than using the pressure proportional valve????
Chevs of the 40s Parts
Hamby Motors Vintage Parts SC
TECH LINKS REFERENCE & MISC
DAVE's Small-Body HEIs
DeCode This VIN Decoder
