Author Topic: Power steering  (Read 16240 times)
Power steering
« on: October 11, 2018, 08:37:50 AM »
Any one running power rack and pinion???  if so what is your setup?
Re: Power steering
« Reply #1 on: October 11, 2018, 12:57:10 PM »
Mine is not power steering.  The set up I have is a TCI front end with a rack behind the crossmember, a Dodge Omni one I believe.
Re: Power steering
« Reply #2 on: October 11, 2018, 01:07:15 PM »
Like Tom I'm using a Dodge Omni rack behind the front member  but mine is a power rack with a Delco pump. The front suspension is Kugel.
Re: Power steering
« Reply #3 on: October 11, 2018, 01:30:38 PM »
my 35 coupe has a kugel with Omni rack, NO power assist.  Not needed even with 60 series tires.
My 35 phaeton has a cricket rack about 5 turns lock to lock on JAG XKE ifs, way to slow.  Have another OMNI rack going to swap in place.
Unless you have a really heavy car the Omni rack is sufficient.
Re: Power steering
« Reply #4 on: October 11, 2018, 06:26:15 PM »
Searching for all parts to convert to power rack...wanting to get the smallest power steering pump,found one that you can order 1200 psi or 850 psi....had a question on required or acceptable pressure on the Omni power rack...would the 850 psi pump be compatible with the Omni rack...rather than using the pressure proportional valve????
