Author Topic: TBI tuning option.  (Read 1808 times)
  • Drive it!
Re: TBI tuning option.
« Reply #1 on: January 04, 2018, 12:54:44 PM »
Who does the tuning?
« Reply #2 on: January 04, 2018, 01:22:09 PM »
Probably the easiest method is to datalog with TunerPro RT, then flash a EPROM for the ECM.  I have had luck de-soldering the 1227747 ECM PROM and soldering in a zif socket.
In my trucks case I chose to remove the TBI setup and install a TPI setup then use the TPI ECM.  Here is a pic of the conversion I put in my 1994 Chevy truck.  A lot more torque than the TBI setup.
  • Drive it!
« Reply #3 on: January 04, 2018, 06:09:42 PM »
My first fuel injection sway was a TPI and I've always had a soft spot for them.  It just begs to be retrofitted with a Megasquirt unit.  Built a MS several years ago.  Get to learn lots about electronics and fuel injection in general.  Haven't done much with the TunerPro.
« Reply #4 on: January 04, 2018, 07:25:27 PM »
It's kinda fun...but it takes me a while to relearn stuff I did a couple months ago :o
I use TunerPro Rt to read, tune and re-flash the 16188051 PCM's for LT1 engines.  You'll need Moats Flash & Burn to flash the EPROMs in the TBI engines.
Have used this free tuning site with real good luck for the LT1 stuff:
http://fbodytech.com/bin-files-2/free-online-tuning-service/
28chevyguy
« Reply #5 on: January 07, 2018, 10:32:10 AM »
^^^  I'm running a '90 Pontiac McLaren grand prix turbo with 727 ecm ... prom removed and replaced with re- burnable chip.. car makes around 450-475 hp on a  little aluminum chevy  3.1 engine ... i have been modding that car for almost a decade now .
anyways,  yes there is plenty of stuff you can do with obd1 , the bins are out there .
