Author Topic: Source for fiberglass panel stock  (Read 2058 times)
« on: November 06, 2017, 06:15:15 PM »
Looking for a source where I can purchase some fiberglass panel stock - even gel coated on one side would be great. Need to cut out some mounting brackets etc. Sheets in the 24X24" range would be great.
  • Drive it!
Re: Source for fiberglass panel stock
« Reply #1 on: November 06, 2017, 08:32:10 PM »
Not sure how stout you need it but I always use the shower panels from Lowes.  They are 4' x 8' sheets, smooth on one side.  I don't use them for brackets but door cards and interior panels.  May have to spray some Pam on your workbench and lay up as many layers as you need.  For larger pieces like that I've used a roller then just threw everything away after.  I'm sure you already know this!
« Reply #2 on: November 06, 2017, 08:38:12 PM »
Check WW Grainger...look at the line of acrylic , plastics and hard pvc sheet....I look at their on line catalog
« Reply #3 on: November 07, 2017, 06:18:41 PM »
Ed another thing you might check out, local truck repair shops for thicker glass chunks. (1/8" to 1/4")  I've always had a good selection of chunks off busted up truck/school bus hoods laying around for various projects. Usually most shops will give you a whole hood for the taking.
Add: Yep the older stuff had flater panels. The tops of most sleepers were fiberglass and pretty flat.  Aftermarket racing hoods and decklids. Early this summer I tossed an aftermarket 73-78 chevy pick-up hood that had separated from the inner structure and blew off in the wind.
« Last Edit: November 07, 2017, 07:46:16 PM by sammons »
« Reply #4 on: November 07, 2017, 06:41:52 PM »
10-4 been checking out my local Peterbilt salvage area...nothing yet. Those new tractor fiberglass front ends don't have a flat surface anywhere.  Need to check out my local auto salvage yard.. kind remember seeing some of those older RV's with fiberglass panels parked out back. They are only open Fri/Sat..I like walking around there anyway.
« Reply #5 on: November 09, 2017, 11:15:02 AM »
Just made some fiberglass angle by laying the glass into a length of steel angle iron. The fiberglass running boards are about 2-1/2" short since I increased the wheelbase.  Made a mold from the running board and now have a cast piece to work in.
« Reply #6 on: November 09, 2017, 03:43:41 PM »
Where did you get the running board from???
« Reply #7 on: November 09, 2017, 07:44:42 PM »
I bought them as a package deal with fenders off craigslist. Think they are Speedway Motors stuff...I suspect they are from a 34 Master.
« Reply #8 on: November 10, 2017, 09:22:51 AM »
Correction..they are for a 33 Master.
