Author Topic: Tom...another measurement please?  (Read 1425 times)
« on: November 06, 2017, 11:46:16 AM »
Tom...trying to mock up a set of fiberglass fenders on my channeled/raked 33 Master...can you give me the approx outer distance the front fenders are from the body near the door hinge.  Approx is all I need.
Re: Tom...another measurement please?
« Reply #1 on: November 06, 2017, 02:16:18 PM »
Ed...photo of mine...might help..roughly 14.25 inches ...as you see where I put the tape end....I also have running board off on drivers side of you need measurement from frame to end of fender...
« Last Edit: November 06, 2017, 02:31:44 PM by FATnLOW »
« Reply #2 on: November 06, 2017, 05:58:45 PM »
OK looking at your measurement if you moved the tape up to the door skin it would be in the 13" range...that's about where I'm at.  Fitting a set of fiberglass fenders to my 33M project.  The car is channeled and raked so the front end drops down into the fenders ...plus I extended the hood by 5" and laid the radiator back.  Increased the wheelbase requiring me to lengthen the running boards at some point.  Will most likely cut a couple of inches off the bottom of the doors to allow mounting the running boards higher...my Winter project.
« Reply #3 on: November 06, 2017, 06:15:14 PM »
Ed,
Here's what I got on mine.
« Reply #4 on: November 06, 2017, 06:16:51 PM »
Thanks Tom...I'm in the range I need to be.
