Author Topic: need 68 Camaro RS wiring diagram  (Read 1499 times)
28chevyguy
« on: October 06, 2017, 08:43:03 AM »
been looking all over google for one ,  they either want me to pay 19.99 or I can get one that is a sample pic , gets wicked blurry when you try to enlarge it .   Anyone know where there is a good wiring diagram stash on the net?>?
Re: need 68 Camaro RS wiring diagram
« Reply #1 on: October 06, 2017, 10:29:01 AM »
I still haven't came across my factory Camaro manuals, I may have given them to my brother. I found two referrences on the net, under 67-8 rs headlight door wiring diagrams. "Just Answer" has the full GM '68 wire diagram.(pic below, I have to image shrink to load here so that makes it fuzzy also)"pozziracing" also had links and pic of diagrams, some download pdf files.
http://www.pozziracing.com/67rsheadlightdoors.htm
Sorry link doesn't seem to work, i posted screen pics of the site links below.
I can read the text on the "just answer" pic on my phone, but as I blow it up it does get a bit fuzzy but is the best i've found. Pretty much all this era Chevy wiring was very similar and most colors were the same. Good luck.
« Last Edit: October 06, 2017, 11:00:10 AM by sammons »
28chevyguy
« Reply #2 on: October 06, 2017, 01:48:49 PM »
thanks !  the third one down is the one I need ,  still trying to zoom in but having no luck .    I remember picking them off old forums  , before photobucket plagued everything .    I have the whole harness to the car laid out , know where 75% of it goes just want to label things and fix a few loose ends .  Also have one melted ignition wire and a over heated alt + wire that needs to be replaced.
