Author Topic: Need blower motor & fan for Hupp universal car heater  (Read 3915 times)
Re: Need blower motor & fan for Hupp universal car heater
« Reply #15 on: August 09, 2017, 10:14:05 AM »
Ed...It has always been my understanding that you could reverse either the field winding or the armature winding polarity but not both to change the rotation of a wound field DC motor.  Should be doable .
I spoke with our local starter rebuild shop...he said only magnet motors can be reversed by rotating the magnets?  I was going to try it anyway but after opening it the brushes need R&R and the fiber thrust washers need replacement - have no idea where to get them - but still looking. Do have an assortment of brushes that I can make work.
Not a big deal I have a couple of potential motor sources.
« Reply #16 on: August 21, 2017, 06:23:29 PM »
FYI:  I just installed a WILDGAME INNOVATIONS 12 VOLT DC FEEDER MOTOR p/n 12VM...larger diameter than the OEM motor. Had to file off a little on the outer bushing side cap but it fits and is bi-directional ;)
http://www.ebay.com/itm/WILDGAME-INNOVATIONS-12-VOLT-DC-FEEDER-MOTOR-p-n-12VM-v-n-990-80ZYT16-6415-NEW-/182690718398?hash=item2a893722be:g:uYgAAOSwd~RZQHxx
Picked up another one of those heaters on ebay for $48 shipped..it has the 12v motor, works and is good to go.
« Reply #17 on: August 21, 2017, 08:13:42 PM »
Ed...Were you able to use the fan blade from the old motor?
« Reply #18 on: August 22, 2017, 07:27:51 AM »
Yes!
